Home » Archived » BIRT » runtime connection profile change not working
runtime connection profile change not working [message #250567] Tue, 31 July 2007 12:50 Go to next message
I work with a webapp under Tomcat 5.5, when deploying a profile different
than the one used in development, the connection information from profile
is not used.
I read ProfilePropertyProviderImpl.java. Then I have updated the
Connection Profile Store Url to a url like "file:/// "
(the log show this as OdaConnProfileStorePath). I have given a valid url,
but the information from the connection profile is not used
The idea is to have developers work with a development database, and have
the project manager deploy the app with a connection profile with the same
file name, but different database, user and password. The project manager
does not make the change with Eclipse, it only copies a different profile
file.
Remark: When working in the Eclipse development environment, any update to
the connection profile is updated into report datasource definition.
Apparently report uses the information copied into .rptdesign file
I have also search the news and found similar problems. Linda Chan replied
someone changes the profile and oda framework merges the properties.
However someone can reproduce the situation I have described by using
BirtViewerExample with Tomcat, deploying there a report, and then changing
the connection profile.
Does someone have an example of a working configuration like the one
described?
Could someone give an example of a valid connection profile file url?
Re: runtime connection profile change not working [message #251916 is a reply to message #250567] Thu, 09 August 2007 18:11 Go to previous message
We found that some Eclipse plugins are missing in the BIRT Runtime
packaging. As a result, the plugin responsible for the lookup of connection
properties from an external connection profile is not loaded.
This will be fixed in BIRT 2.2.1, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=199233 .
In the mean time, you can workaround it by manually adding those 3 missing
Eclipse plugins in your BIRT web application installation, under the
ReportEngine/plugins folder.
Linda
"rcuevas" <rcnunhes@gmail.com> wrote in message
news:0e7f8481a9f38fc74db418049e36e529$1@www.eclipse.org...
> Hi
> is not used. I read ProfilePropertyProviderImpl.java. Then I have updated
> the Connection Profile Store Url to a url like "file:/// " (the log show
> this as OdaConnProfileStorePath). I have given a valid url, but the
> file.
> described?
> Thanks
Previous Topic:Parameter Localization
Next Topic:How to do custom ordering for Crosstab columns?
Current Time: Tue Jul 15 12:12:16 EDT 2025
Powered by FUDForum. Page generated in 0.05994 seconds
