Home » Archived » Visual Editor (VE) » Error in Plugin Installation
Error in Plugin Installation [message #24639] Thu, 11 March 2004 06:23 Go to next message
Originally posted by: csplrj.yahoo.co.in
I have Installed Eclipse
by unzipping it
to Root Directory
So a folder Eclipse is created and all other files unzipped
Now
I unzip the file
VE-runtime-0.5.0.zip,emf_2.0.0_20040225_1234SL.zip,GEF-runti me-I20030327
to Eclipse Directory
Afterwards I start the Eclipse
And Then When I see the Summary Details of the Eclipse
I find following Errors
!SESSION Mar 09, 2004 23:31:27.520
java.version=1.4.1_05
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.pde.core 2 1 Mar 09, 2004 23:31:27.520
!MESSAGE Problems while scanning external plug-ins
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 09, 2004 23:31:27.520
!MESSAGE Plug-in "org.eclipse.jem" was disabled due to missing or disabled
prerequisite plug-in "org.eclipse.emf.ecore.xmi".
!MESSAGE Plug-in "org.eclipse.jem.proxy" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.jem".
!MESSAGE Plug-in "org.eclipse.jem.beaninfo" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.jem.proxy".
!MESSAGE Plug-in "org.eclipse.jem.beaninfo.ui" was disabled due to missing
or disabled prerequisite plug-in "org.eclipse.jem.beaninfo".
!MESSAGE Plug-in "org.eclipse.ve.propertysheet" was disabled due to
missing or disabled prerequisite plug-in "org.eclipse.emf.common".
!SUBENTRY 1 org.eclipse.core.runtime 2 1 Mar 09, 2004 23:31:27.530
!MESSAGE Plug-in "org.eclipse.ve.cde" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.ve.propertysheet".
!MESSAGE Plug-in "org.eclipse.ve.java.core" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.ve.cde".
!MESSAGE Plug-in "org.eclipse.ve.jfc" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.ve.java.core".
!MESSAGE Plug-in "com.ibm.etools.emf.event" was disabled due to missing or
disabled prerequisite plug-in "org.eclipse.emf.ecore".
!MESSAGE Unable to satisfy prerequisite constraint from
"org.eclipse.jem.workbench" to "org.eclipse.jem".
!MESSAGE Plug-in "com.ibm.etools.emf.ecore.utilities" was disabled due to
missing or disabled prerequisite plug-in "org.eclipse.emf.ecore.xmi".
!MESSAGE Plug-in "com.ibm.etools.emf.workbench" was disabled due to
"com.ibm.etools.emf.ecore.utilities".
I am new to Eclipse
Please give me the reason and Way to rectify it
Thanks in advance
Chirag
Re: Error in Plugin Installation [message #24978 is a reply to message #24639] Thu, 11 March 2004 09:27 Go to previous messageGo to next message
To resolve this it would be helpful to know what version of Eclipse you're
using. ;-)
> by unzipping it
> to Root Directory
> Now
> I unzip the file
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> I am new to Eclipse
> Thanks in advance
> Chirag
Re: Error in Plugin Installation [message #25021 is a reply to message #24639] Thu, 11 March 2004 10:13 Go to previous messageGo to next message
Originally posted by: richkulp.NO.SPAM.us.ibm.com
You are using an incompatible mix of versions. Please check the pre-reqs
list on the download page. It will tell you the correct mix. It is very
important because versions cannot be mixed together.
For example you are using the 20040225 driver of EMF. That driver WILL
NOT work with VE 0.5.0, and unless that is a typo, GEF I20030327 is way,
way downlevel and will not work with VE 0.5.0. And as R.U. Deranged
asked, what version of eclipse are you using? 3.0 of eclipse doesn't
work with 0.5.0 VE.
> by unzipping it
> to Root Directory
> Now
> I unzip the file
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #25100 is a reply to message #25021] Thu, 11 March 2004 12:33 Go to previous messageGo to next message
Originally posted by: csplrj.yaho.co.in
Thanks I am using Eclipse 3.0
Well I had a mix up of different versions
Can you give me correct hyperlink for the correct versions to download
As I went to the Hyperlink
http://dev.eclipse.org/viewcvs/indextools.cgi/~checkout~/emf -home/downloads/dl.html?cvsroot=Tools_Project
to find out the correct Versions
The first Statement written over there is
Use Eclipse Version 3.0 (M6) for EMF 2.0.0, Eclipse Version 2.1.2 for EMF
1.1.1/EMF 1.1.1.1, Eclipse Version 2.1.1 for EMF 1.1.0, or Eclipse Version
2.1 for EMF 1.0.2.
So According to that I have to download EMF 2.0 and that version has been
downloaded by me but as you said it will not work with VE 0.5.0 So please
can you give me hyperlink of the correct versions suitable for Eclipse 3.0
I have to download EMF,GEF,VE for ECLIPSE 3.0
As I am new to Eclipse
Is it correct that after installing these components I can create Java
Panels,Applets,Frames etc In an Visual environment I mean click and drag
Thanks in advance
Bye
Chirag
> work with 0.5.0 VE.
> > by unzipping it
> > to Root Directory
> > Now
> > I unzip the file
Re: Error in Plugin Installation [message #25141 is a reply to message #25100] Thu, 11 March 2004 12:44 Go to previous messageGo to next message
Er, but which build of 3.0 do you have installed? We can't determine exactly
which versions you'll need until we know that. ;-)
> 2.1 for EMF 1.0.2.
> Thanks in advance
> Bye
> Chirag
>> work with 0.5.0 VE.
>> > by unzipping it
>> > to Root Directory
>> > Now
>> > I unzip the file
Re: Error in Plugin Installation [message #25182 is a reply to message #25141] Thu, 11 March 2004 12:49 Go to previous messageGo to next message
Originally posted by: abuse.yahoo.co.in
This is the Zip File Name
eclipse-SDK-3.0M6-win32[1].zip
> > 2.1 for EMF 1.0.2.
> > Thanks in advance
> > Bye
> > Chirag
> >> work with 0.5.0 VE.
> >> > by unzipping it
> >> > to Root Directory
> >> > Now
> >> > I unzip the file
Re: Error in Plugin Installation [message #25223 is a reply to message #25182] Thu, 11 March 2004 13:57 Go to previous messageGo to next message
The 1.0 stream version of VE never supported M6 IIRC.
My advice would be to upgrade to M7 or the latest integration build since M6
is much buggier anyhow.
Re: Error in Plugin Installation [message #25264 is a reply to message #25100] Thu, 11 March 2004 15:07 Go to previous messageGo to next message
Everything the VE required is listed on the download page of the VE
driver itself. The VE download page's first section says "Requirements"
and the links there go to the drivers of Eclipse, EMF, and GEF that are
required.
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #25303 is a reply to message #25223] Fri, 12 March 2004 00:18 Go to previous messageGo to next message
Originally posted by: nospam.yahoo.co.in
Can You Give me the complete hyperlink of VE,GEF and EMF versions to
download to match the Eclipse 3.0 M7 version so that I can download all
Eclipse and plugins in one slot
Thanks in advance
Chirag
Re: Error in Plugin Installation [message #25344 is a reply to message #25264] Fri, 12 March 2004 00:21 Go to previous messageGo to next message
But Is there any version of VE for Eclipse 3.0 M6
As I can't find it out over the page
Is it under development
Thanks in advance
> required.
Re: Error in Plugin Installation [message #25384 is a reply to message #25344] Fri, 12 March 2004 04:36 Go to previous messageGo to next message
Chirag wrote:
> Thanks
As I said previously, there was no version for M6. VE support skipped from M5
to M7.
Here's what you need for M7:
EMF 2.0.0 build 20040225_1234SL:
http://download.eclipse.org/tools/downloads/emf/emf_2.0.0_20 040225_1234SL.zip
Note: you *might* be able to use the latest integration build, I200403081633,
but I wouldn't bet on it. Rich would know for sure. If you want to try:
http://download.eclipse.org/tools/downloads/emf/emf-runtime- I200403081633.zip
GEF build I20040212:
http://download.eclipse.org/tools/gef/downloads/drops/I-I200 40212-200402121128/GEF-runtime-I20040212.zip
VE Integration Build I20040219:
http://download.eclipse.org/tools/ve/downloads/drops/I-I2004 0219-200402191909/VE-runtime-I20040219.zip
Re: Error in Plugin Installation [message #25425 is a reply to message #25384] Fri, 12 March 2004 04:38 Go to previous messageGo to next message
I am downloading the Appropriate Versions
Thanks Again
> Chirag wrote:
> > Thanks
> to M7.
Re: Error in Plugin Installation [message #25545 is a reply to message #25425] Fri, 12 March 2004 10:00 Go to previous messageGo to next message
Chirag,
For future reference. The download page of the VE drivers already has
all of the links to all of the pre-reqs. There's no need for us to list
them here in the newsgroup.
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #25661 is a reply to message #25545] Fri, 12 March 2004 10:46 Go to previous messageGo to next message
In the interest of fairness, the EMF page that is linked to from VE's
requirements list can be confusing for new users. The link should point to a
*specific* build, not a page with a dozen different builds. ;-)
Re: Error in Plugin Installation [message #25717 is a reply to message #25661] Fri, 12 March 2004 10:57 Go to previous messageGo to next message
Actually the download build zip file link does point to the actual
download zip file. The build page link only points to the actual page.
There is no marker in the download page that I can reference to point to
the actual required version in the page. EMF doesn't have it structured
like Eclipse and GEF does where there is a separate page for each
driver, which it makes it difficult.
However, starting with the next build, the integration build id to use
for EMF will be listed instead of just saying 2.0.0.
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #25747 is a reply to message #25717] Fri, 12 March 2004 11:29 Go to previous messageGo to next message
Ah, I had my blinders on, sorry. I've gotten into the habit of clicking on
"build page" to retrieve what I need because the Eclipse runtime link points
to a Win32 zip when I'm looking for Linux instead, and for the EMF and GEF
items because I want to make sure I'm getting the most recent compatible
builds.
Do the links to the EMF and GEF zip files get updated when new integration
builds of them are released, or do you wait until the next VE release to
update them?
Re: Error in Plugin Installation [message #25756 is a reply to message #25747] Fri, 12 March 2004 12:38 Go to previous message
Mostly every integration build of VE uses the latest integration builds
of Eclipse, GEF, and EMF builds. There are exceptions but in general
this is true.
> builds.
> update them?
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #584239 is a reply to message #24639] Thu, 11 March 2004 09:27 Go to previous message
using. ;-)
> by unzipping it
> to Root Directory
> Now
> I unzip the file
> I am new to Eclipse
> Thanks in advance
> Chirag
Re: Error in Plugin Installation [message #584260 is a reply to message #24639] Thu, 11 March 2004 10:13 Go to previous message
work with 0.5.0 VE.
> by unzipping it
> to Root Directory
> Now
> I unzip the file
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #584289 is a reply to message #25021] Thu, 11 March 2004 12:33 Go to previous message
2.1 for EMF 1.0.2.
Thanks in advance
Bye
Chirag
> work with 0.5.0 VE.
> > by unzipping it
> > to Root Directory
> > Now
> > I unzip the file
Re: Error in Plugin Installation [message #584298 is a reply to message #25100] Thu, 11 March 2004 12:44 Go to previous message
> 2.1 for EMF 1.0.2.
> Thanks in advance
> Bye
> Chirag
>> work with 0.5.0 VE.
>> > by unzipping it
>> > to Root Directory
>> > Now
>> > I unzip the file
Re: Error in Plugin Installation [message #584309 is a reply to message #25141] Thu, 11 March 2004 12:49 Go to previous message
> > 2.1 for EMF 1.0.2.
> > Thanks in advance
> > Bye
> > Chirag
> >> work with 0.5.0 VE.
> >> > by unzipping it
> >> > to Root Directory
> >> > Now
> >> > I unzip the file
Re: Error in Plugin Installation [message #584322 is a reply to message #25182] Thu, 11 March 2004 13:57 Go to previous message
Re: Error in Plugin Installation [message #584333 is a reply to message #25100] Thu, 11 March 2004 15:07 Go to previous message
required.
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #584347 is a reply to message #25223] Fri, 12 March 2004 00:18 Go to previous message
Thanks in advance
Chirag
Re: Error in Plugin Installation [message #584360 is a reply to message #25264] Fri, 12 March 2004 00:21 Go to previous message
Thanks in advance
> required.
Re: Error in Plugin Installation [message #584370 is a reply to message #25344] Fri, 12 March 2004 04:36 Go to previous message
Chirag wrote:
> Thanks
to M7.
Re: Error in Plugin Installation [message #584381 is a reply to message #25384] Fri, 12 March 2004 04:38 Go to previous message
Thanks Again
> Chirag wrote:
> > Thanks
> to M7.
Re: Error in Plugin Installation [message #584423 is a reply to message #25425] Fri, 12 March 2004 10:00 Go to previous message
Chirag,
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #584459 is a reply to message #25545] Fri, 12 March 2004 10:46 Go to previous message
Re: Error in Plugin Installation [message #584492 is a reply to message #25661] Fri, 12 March 2004 10:57 Go to previous message
Thanks, Rich Kulp
Re: Error in Plugin Installation [message #584516 is a reply to message #25717] Fri, 12 March 2004 11:29 Go to previous message
builds.
update them?
Re: Error in Plugin Installation [message #584544 is a reply to message #25747] Fri, 12 March 2004 12:38 Go to previous message
this is true.
> builds.
> update them?
Thanks, Rich Kulp
Previous Topic:problems extending JPanel
Next Topic:problems extending JPanel
Current Time: Sat May 10 02:39:55 EDT 2025
Powered by FUDForum. Page generated in 0.07047 seconds
