Home » Eclipse Projects » Eclipse Platform » How to use different JRE in different project?
How to use different JRE in different project? [message #250352] Tue, 08 June 2004 03:18 Go to next message
I want to use different JRE in different project in the same workspace, how
can I do?
I'm using the 3M8. In the workspace preferences it says "the checked JRE
will be used by default to build and run Java programs".
Re: How to use different JRE in different project? [message #250380 is a reply to message #250352] Tue, 08 June 2004 05:17 Go to previous messageGo to next message
select the properties of the project itself
there you can overwrite pretty much everything.
johan
> can I do?
Re: How to use different JRE in different project? [message #250426 is a reply to message #250380] Tue, 08 June 2004 07:53 Go to previous messageGo to next message
Thanks. But I cann't find where to set that property in the project
properties page.
"Johan Compagner" <jcompagner@j-com.nl> wrote in message
news:ca3vob$f7c$1@eclipse.org...
> johan
how
> > can I do?
Re: How to use different JRE in different project? [message #250452 is a reply to message #250426] Tue, 08 June 2004 09:04 Go to previous messageGo to next message
Originally posted by: smesh.openrules.com
Items of interest (3.0 RC1 as an example):
- "Window/Properties/Installed JRE"
- "Window/Properties/Compiler/Compliance and Classfiles"
- "Project/Properties/Java Build Path/Libraries/Add Library/JRE System
Library/Alternate JRE"
Sam Mesh - http://openrules.com
Re: How to use different JRE in different project? [message #250724 is a reply to message #250452] Tue, 08 June 2004 20:36 Go to previous messageGo to next message
Hi.
In fact I'm trying the JDK 1.5.0 beta, and it seems not compiling with the
1.5.0 even I set "installed jre" to 1.5.0.
For the "enhanced for loop" it just reports syntax errors.
I'm using M8, in the "Window/Properties/Compiler/Compliance and
Classfiles/Compiler compliance level" there is only 1.3/1.4, is that the
problem?
Re: How to use different JRE in different project? [message #250948 is a reply to message #250724] Wed, 09 June 2004 10:21 Go to previous messageGo to next message
Originally posted by: eclipse.rizzoweb.com
ooo wrote:
> Hi.
> problem?
As my 8-year-old nephew would say: "Duh!" ;-)
The new JDK 1.5 syntax elements (like the "enhanced" for loop) are
unknown to Eclipse's parser and compiler (Eclipse does not use javac to
compile, and it is doing lots of internal parsing of code to provide the
rich features it has).
That said, there is a project named Cheetah that is gradually
introducing JDK 1.5 support into Eclipse. Try searching for it at
www.eclipse.org.
HTH,
Eric
Re: How to use different JRE in different project? [message #251316 is a reply to message #250948] Thu, 10 June 2004 00:46 Go to previous message
Ok. thank you point out.
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:ca75th$crc$1@eclipse.org...
> ooo wrote:
> > Hi.
the
> > problem?
> www.eclipse.org.
> HTH,
> Eric
Previous Topic:run PDE unittest from ant script.
Next Topic:navigator selection
Current Time: Fri Jul 18 03:29:03 EDT 2025
Powered by FUDForum. Page generated in 0.05237 seconds
