Home » Archived » BIRT » Page breaks using the API
Page breaks using the API [message #250265] Sun, 29 July 2007 14:50 Go to next message
I want to add a page break that is always_after to a table. While this
is easy enough in the Designer I am trying to do this using the API.
Do I use styles? If so how, I always get a null from table.getStyle. I
f I create a new style from the element factory when I try
table.setStyle(newStyle) I get "The style "NewStyle" used by
Table("table") is not found"?
Any suggestions on how to do something as simple as add a page break to
a report item using the API?
Lester
Re: Page breaks using the API [message #250423 is a reply to message #250265] Mon, 30 July 2007 12:46 Go to previous messageGo to next message
Lester,
This is a property of the table and you should be able to do this using
the TableHandle like:
th.setPropertyBinding("pageBreakAfter", "always");
Jason
> Lester
Re: Page breaks using the API [message #250754 is a reply to message #250423] Wed, 01 August 2007 11:04 Go to previous messageGo to next message
Thanks Jason,
This worked quite well. One last question though were is the best place
to find all the properties and the possible values for a given report item.
I realize for a single item I could use getProperties to see the
available properties but it won't provide the potential values.
Is there some documentation somewhere?
Lester
Jason Weathersby wrote:
> Lester,
> Jason
>> this is easy enough in the Designer I am trying to do this using the API.
>> I f I create a new style from the element factory when I try
>> to a report item using the API?
>> Thanks,
>> Lester
Re: Page breaks using the API [message #250879 is a reply to message #250754] Wed, 01 August 2007 23:50 Go to previous message
Lester,
Look at the ROM
http://www.eclipse.org/birt/phoenix/ref/rom/elements/Table.h tml
Jason
Lester Mundt wrote:
> Thanks Jason,
> Lester
>> Lester,
>> using the TableHandle like:
>> Jason
>>> API.
>>> table.getStyle. I f I create a new style from the element factory
>>> when I try table.setStyle(newStyle) I get "The style "NewStyle" used
>>> by Table("table") is not found"?
>>> Thanks,
>>> Lester
Previous Topic:checkbox with data values in BIRT Report output
Next Topic:Simple Parameter Question
Current Time: Tue Jul 22 08:28:14 EDT 2025
Powered by FUDForum. Page generated in 0.29866 seconds
