Home » Eclipse Projects » Eclipse Platform » Appending a newline to a Document
Appending a newline to a Document [message #250252] Mon, 07 June 2004 16:18 Go to next message
I'm working on a little view that receives text messages and appends them to
the end of a document. I have no trouble getting regular strings to append
using document.replace(document.getLength(), 0, text) except if the text
begins or ends with a newline character. If the text starts with a newline,
then the document gets cleared. If it ends with a newline, no subsequent
messages will be logged in the view.
I would like the messages to be able to start and end with newlines so that
the text doesn't run in one big, long string. I'm using 3.0 M9. Does anyone
have any ideas?
Del.
Re: Appending a newline to a Document [message #250397 is a reply to message #250252] Tue, 08 June 2004 06:20 Go to previous messageGo to next message
What you do should work. What are the document contents (document.get())
after a replace that does not work? Is document content wrong, or is it
just what is being displayed in your view?
If you don't find out what's wrong, you should file a bug report against
platform-text.
-t
Del wrote:
> have any ideas?
> Del.
Re: Appending a newline to a Document [message #250558 is a reply to message #250397] Tue, 08 June 2004 12:09 Go to previous message
I just figured it out, thanks.
The document.get() showed the right information, so the content was right.
There was a problem with the view. I played around with the SWT style for a
little while and everything was fine.
Del
"Tom Eicher" <eclipse@tom.eicher.name> wrote in message
news:ca43e9$kfu$1@eclipse.org...
> platform-text.
> -t
> Del wrote:
> > Hi,
them to
append
newline,
that
anyone
> > have any ideas?
> > Del.
Previous Topic:Plugins not loaded
Next Topic:What happened to the JFace content-assist lightbulb decoration in M8?
Current Time: Tue Jul 15 00:12:33 EDT 2025
Powered by FUDForum. Page generated in 0.08896 seconds
