Home » Language IDEs » Java Development Tools (JDT) » Accessing JavaApplicationLaunchShortcut.launch(...)
Accessing JavaApplicationLaunchShortcut.launch(...) [message #250229] Sun, 16 December 2007 13:33 Go to next message
Hi!
I want to "Run as -> Java Application" a java file
invoked from my code.
Thus I would like to call the launch(...) method of
JavaApplicationLaunchShortcut which is part of
theorg.eclipse.jdt.debug.ui plugin.
I wonder why, but I can't access the code. I even
tried to use reflection to load "org.eclipse.jdt.
internal.debug.ui.launcher.JavaApplicationLaunchShortcut"
but the class cannot be found although it is there.
I am looking for one of the following two solutions:
1) Accessing JavaApplicationLaunchShortcut directly or
2) Doing it the proper why to look up the registered
extensions at the org.eclipse.debug.ui.launchShortcuts
extension point and invoke launch the functionality.
Any help appreciated!
Nicolai
I'm using an evaluation license of nemo since 104 days.
You should really try it!
http://www.malcom-mac.com/nemo
Problem solved [message #250233 is a reply to message #250229] Mon, 17 December 2007 04:58 Go to previous message
I solved the problem using the proper way.
Here is my code:
ILaunchShortcut launcher = null;
IConfigurationElement launcherElement = null;
IConfigurationElement[] elements =
Platform.getExtensionRegistry().getConfigurationElementsFor( "org.ecli
pse.debug.ui.launchShortcuts");
for (IConfigurationElement element : elements) {
if
(element.getAttribute("id").equals("org.eclipse.jdt.debug.ui.localJav
aShortcut")) { launcherElement = element;
break;
try {
launcher = (ILaunchShortcut)
launcherElement.createExecutableExtension("class");} catch
(CoreException e) {
e.printStackTrace();
if (launcher != null)
launcher.launch(selection, ILaunchManager.RUN_MODE);
Like Eclipse is doing it I look for plugins that registered a launch
shortcut. Then I look for the "Run as -> Java Application" shortcut
and let the plugin architecture create an instance of the class.
Finally I can call launch(...) on that instance.
Nicolai
I'm using an evaluation license of nemo since 105 days.
Previous Topic:How to suppress 'never used locally' warning for annotated method
Next Topic:'unable to instantiate' exception when loading wizardPage
Current Time: Sun Jul 27 02:53:02 EDT 2025
Powered by FUDForum. Page generated in 0.03359 seconds
