Home » Language IDEs » Java Development Tools (JDT) » 'unable to instantiate' exception when loading wizardPage
'unable to instantiate' exception when loading wizardPage [message #250217] Fri, 14 December 2007 19:19 Go to next message
Originally posted by: jeff_r2.verifone.com
Could not find a plugin newsgroup so here goes.
I added a wizardPage to extend the 'newProject' wizard, at this point very
simple, just stubs.
the pageClass extends WizardPage. and
the operationClass implements Runnable.
When executing a newProject I get the execption:
org.eclipse.cdt.managedbuilder.core.BuildException: Plug-in
"path.environment" was unable to instantiate class
"path.environment.wizardConfigFilePage".
NOTE: I replaced the full path to 'path' in the execption.
Creating the extension point and classes were straightforward but there
must be something fundamental going on here. Can someone point in to any
doc's or examples.
thanks.
Jeff
Re: 'unable to instantiate' exception when loading wizardPage [message #250225 is a reply to message #250217] Sat, 15 December 2007 15:01 Go to previous messageGo to next message
> very simple, just stubs.
> doc's or examples.
> thanks.
> Jeff
Check to make sure that your wizard page has the appropriate
constructors. Also check to make sure that it isn't throwing an
exception in the constructor.
Re: 'unable to instantiate' exception when loading wizardPage [message #250237 is a reply to message #250225] Mon, 17 December 2007 13:00 Go to previous messageGo to next message
I used the create class wizard and the ctor's looked good, I put a line of
code in each ctor so as to breakpoint, and the breakpoint is never hit
either on my line of code or the super() call. Looks like things are
bombing out before the ctor is called but if it was a path problem I would
expect to see a 'class not found' exception, instead of the 'unable to
instantiate'.
Here are the constructors:
public wizardConfigFilePage(String pageName) {
super(pageName);
int i = 0;
public wizardConfigFilePage(String pageName, String title,
ImageDescriptor titleImage) {
super(pageName, title, titleImage);
int i = 0;
Re: 'unable to instantiate' exception when loading wizardPage [message #250244 is a reply to message #250237] Mon, 17 December 2007 13:39 Go to previous message
Figured it out.
The class is constructed using a default ctor, which the class wizard did
not generate since the parent (WizardPage) class does not have a default
ctor.
thanks David.
Jeff Reich
Previous Topic:Accessing JavaApplicationLaunchShortcut.launch(...)
Next Topic:Consistency problems when custom builder uses ICompilationUnit for externally up
Current Time: Wed Jul 02 15:25:03 EDT 2025
Powered by FUDForum. Page generated in 0.03862 seconds
