Home » Eclipse Projects » Subversive » How to clear password
How to clear password [message #24614] Mon, 07 July 2008 04:56 Go to next message
Originally posted by: lorenzo.martinelli.tele2.it
I use subversive with JavaHL connector; I've saved my username/password.
I've tried to change the user to connect to svn,
but I continue to connect to apache with the old user.
I've read this article:
http://nlp.cs.byu.edu/~rah67/wordpress/?p=4
but I don't solved my problems
I've used:
Eclipse 3.3.2 and 3.4.
Subversive: 0.7.1 Release
Connectors: 2.0 (JavaHL RC 7)
My OS is XP Professional and SVN's version is 1.5.
The protocol used for connection is https.
Any suggestion is appreciated.
Re: How to clear password [message #24952 is a reply to message #24614] Mon, 07 July 2008 05:04 Go to previous messageGo to next message
Originally posted by: alexander.gurov.polarion.org
Hello Lorenzo,
Native JavaHL connector library uses the following folder in order to
store authentication information:
"c:\Documents and Settings\<USERNAME>\Application Data\Subversion\auth"
Re: How to clear password [message #24965 is a reply to message #24952] Mon, 07 July 2008 07:52 Go to previous messageGo to next message
Thank you for your response.
I've deleted the folder
the file .keyring in eclipse
I recreated my workspace....
but the problem ramain.
Re: How to clear password [message #24989 is a reply to message #24965] Mon, 07 July 2008 11:57 Go to previous messageGo to next message
Hi Subversive Support Team,
we investigated the behaviour that occurs by trying to authenticate
to a subversion server (apache httpd + mod svn)
with an NTLM authentication method.
It seems that when the user is currently logged in on the windows domain,
whatever user and whatever password you type in eclipse, the subversive
plugin
uses the standard login credentials used by the current windows user.
Although it seems perfect for us, we would like to receive from you a
confirmation of this behaviour, since we are implementing our
infrastracture
and version management with apache + mod dav svn + mod ntlm, and we cannot
let it change in the future.
Lorenzo Martinelli
Re: How to clear password [message #25519 is a reply to message #24989] Mon, 14 July 2008 08:40 Go to previous messageGo to next message
Is it possible to have an answer to my previous post?
Re: How to clear password [message #25842 is a reply to message #25519] Thu, 17 July 2008 11:50 Go to previous message
Hello Lorenzo,
We have never tested the described configuration. So, I can't provide
exact answer for your question. But please note that SVN Kit-based
connectors may behaves in a different way in compare to native connectors
because SVN Kit-based ones does not have abilities to interact with the
OS-specific features.
Previous Topic:Merge problem "File not found: revision..." when opening 3-way comparator
Next Topic:Occasional author corruption on commits
Current Time: Sat May 10 11:36:35 EDT 2025
Powered by FUDForum. Page generated in 0.03958 seconds
