Home » Archived » BIRT » Cannot add Report Items in Header by using multiple masterpage
Cannot add Report Items in Header by using multiple masterpage [message #249921] Thu, 26 July 2007 04:31 Go to next message
i use two masterpages in my report(Birt 2.2), in which case i cannot add
any report item into the header in Master Page tab. even when i delete one
masterpage definition and add a item in the header, i still cannot see it
after it is added.
is it a bug in Birt 2.2?
regards
Re: Cannot add Report Items in Header by using multiple masterpage [message #249926 is a reply to message #249921] Thu, 26 July 2007 04:44 Go to previous messageGo to next message
Hi Peng
I have tried your case in both 2.2.0 release build and latest build. I can
not reproduce your issue. Would you like to tell me your build version and
more detail information before you insert the report item into masterpage
header?
Best regards!
Re: Cannot add Report Items in Header by using multiple masterpage [message #249929 is a reply to message #249926] Thu, 26 July 2007 04:47 Go to previous messageGo to next message
The list, table, chart and crosstab which has list of bindings are not
allowed to insert into masterpage header
regards!
Re: Cannot add Report Items in Header by using multiple masterpage [message #249963 is a reply to message #249929] Thu, 26 July 2007 07:23 Go to previous message
Hello Tianli,
i found the reason. In myself defined .library i define two
masterpage(Landscape and protrait). when i try to reuse it in a .template
or a .design file, it does not allow to edit it, say adding report item to
it. in this case i can not reuse the predefined masterpage in .library.
solution: define masterpage in .template and reuse it in .design.
thanks for your feedback,
regards
Previous Topic:Download generated report file
Next Topic:[BIRT2.2.0] CSV Export Problems
Current Time: Thu Jul 17 22:06:03 EDT 2025
Powered by FUDForum. Page generated in 0.07341 seconds
