Resource history under CVSNT [message #249687] |
Fri, 04 June 2004 14:30  |
Originally posted by: vladchuk.socal.rr.com
I am trying to use CVSNT with Eclipse RC1. While I can configure and manage
projects under CVS without a problem I never see any resource histories for
any of the files.
Can anybody help with this issue?
vladchuk
Re: Resource history under CVSNT [message #250128 is a reply to message #249953] |
Mon, 07 June 2004 11:20  |
Martin,
Using prefix indeed solved all my problems. Thanks a lot.
Vladimir Grabarchuk
"Martin Lippert" <lippert@acm.org> wrote in message
news:c9vd13$8a7$1@eclipse.org...
manage
for
> > any of the files.
> I had the same problem (and some more) running CVSNT (2.0.41a) and
> 3.0rc1. I fixed this by using a repository prefix. You can set this at
> the control panel of CVSNT. After setting the prefix I changed my cvs
> repository location in Eclipse to use only the host and the repository
> name. In addition to this I checked the option "pretent to be a unix
> cvs" on the advanced tab of the CVSNT control panel.
> Now I can see file revisions, branches, version tags, etc. Everything
> seems to work fine.
> Hope this helps.
> Best regards,
> Martin
FUDForum. Page generated in 0.48693 seconds
