Moved Birt, now report design errors out [message #249371] |
Mon, 23 July 2007 11:13  |
Originally posted by: not.areal.email
I ran birt a few times from one location, designed and tested a report,
then moved birt to another dir. I've rebooted (win xp) and tried -clean,
but no matter what I cannot open the myreport.rptdesign in birt. There
is a null pointer exception and a stack of other errors starting with
org.eclipse.birt.report.designer.ui.editors.MultiPageReportE ditor.addPag
es(MultiPageReportEditor.java:222)
at org.eclipse.ui.forms.editor.FormEditor.createPages
(FormEditor.java:146)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl
(MultiPageEditorPart.java:283)
There is no 'installer' with birt, so I can't see what the issue is? The
..project file opens, as does the rptconfig file. Under the project menu,
both open project and close project are always disabled (not sure what
they looked like before I moved)
I get the same errors trying to open the report I created with the
tutorial.
Birt looks great, the tutorial well written, thanks.
Re: Moved Birt, now report design errors out [message #249476 is a reply to message #249371] |
Mon, 23 July 2007 21:12  |
Hi Michael
Have you tried to clean all the configuration in Eclipse and workspace?
1, Remove all the config files except config.ini in %Eclipse
Home%\configuration folder.
2, Remove all the .metadata folder in your workspace
3, Restart the eclipse and respecify the workspace direction
Regards!
FUDForum. Page generated in 0.08298 seconds
