Home » Eclipse Projects » Eclipse Platform » using an external jar
using an external jar [message #24537] Wed, 30 April 2003 13:13 Go to next message
Originally posted by: aekapon.comcast.net
i am writing a program that uses a product called the java acme library. The
acme library comes in a jar file called acmeLib.jar. In my java build path,
i add the acmeLib.jar as an External Jar File and my program compiles using
this, but when i try to run it, any time i try to instantiate an object from
the Jar file, i get a java.lang.NoClassDefError and my program crashes, any
suggestions would be greatly appreciated.
Niall
oh, i have used the jar file with applications written outside of eclipse,
so i know the jar file works.
Re: using an external jar [message #24578 is a reply to message #24537] Wed, 30 April 2003 13:16 Go to previous messageGo to next message
sorry, that was java.lang.NoClassDefFoundError
"Niall Little" <aekapon@comcast.net> wrote in message
news:b8p06d$cij$1@rogue.oti.com...
The
path,
using
from
any
> Niall
Re: using an external jar [message #24657 is a reply to message #24537] Wed, 30 April 2003 13:28 Go to previous messageGo to next message
Originally posted by: Olivier_Thomann.ca.ibm.comNOSPAM
On Wed, 30 Apr 2003 13:13:36 -0400, "Niall Little"
You need to add this jar at runtime as well. See the classpath tab of
your launching configuration.
Olivier
Re: using an external jar [message #24738 is a reply to message #24657] Wed, 30 April 2003 13:45 Go to previous messageGo to next message
ok, i found the classpath tab, and that is used when i am running this as a
java applications, but i am writing this using the gef plugin, so as i
understand it, i've been writing this and testing using the "Run-Time
workbench" where there is no such tab. I can't find in the runtime workbench
where to set this class path. Or conversely, where to set the plugins when
running as a Java app.
thanks for the help,
niall
"Olivier Thomann" <Olivier_Thomann@ca.ibm.comNOSPAM> wrote in message
news:fr10bvktlffi8gev1hglbf96jgvjqgnk6j@4ax.com...
The
path,
using
from
any
> Olivier
Re: using an external jar [message #25451 is a reply to message #24738] Thu, 01 May 2003 09:42 Go to previous messageGo to next message
Niall,
For plugins, you should set the classpath in the "Runtime" tab of your
plugin.xml. Click the "Add" button for the "Run-time libraries" section
and include your jars there (the refs are project relative).
You can now update your project classpath by right-clicking in the
"Required Plug-ins" section of the "Dependencies" tab and selecting
"Compute Build Path".
hth
Todd
> niall
> The
> path,
> using
> from
> any
>>Olivier
Re: using an external jar [message #26088 is a reply to message #25451] Thu, 01 May 2003 12:59 Go to previous messageGo to next message
Originally posted by: bob.objfac.com
Does that really work for jar files not in the eclipse folder or workspace?
Plugin writers used to be advised that external jars needed to be part of
some plugin. If it does work with some levels of "../.." is it part of the
API that it works, or just an accident that might change tomorrow?
Another thing Niall might think about. How is the jar file going to be
located when the plugin is installed on someone else's system?
Bob
"Todd Chambery" <chambery@zclipse.org> wrote in message
news:b8r87n$si1$1@rogue.oti.com...
> Niall,
> hth
> Todd
as a
workbench
when
> > niall
library.
> > The
> > path,
> > using
> > from
> > any
> >>Olivier
Re: using an external jar [message #26634 is a reply to message #26088] Thu, 01 May 2003 15:04 Go to previous messageGo to next message
It is an accident. plugin runtimes really must be under the plugin
itself. There is no guarentee of where any other plugin might be
located, so using "../" may not work. Other plugins may be under other
directories than the one plugin.
Re: using an external jar [message #26664 is a reply to message #26088] Thu, 01 May 2003 15:05 Go to previous message
I was assuming that Niall's plugin contained a "lib" directory, but this
makes me think of something a little off topic...
Is there any plan to make something like a library registry for plugins?
Most of the weight of any plugin I work on is in the external
libraries I include.
Drive space really isn't much of an issue any more, but it's a thought.
Todd
> Bob
>>Niall,
>>hth
>>Todd
> as a
> workbench
> when
>>>niall
> library.
>>>The
>>>path,
>>>using
>>>from
>>>any
>>>>Olivier
Previous Topic:Can we access the java parser AST?
Next Topic:Updating Changes to a object in a TreeViewer
Current Time: Fri May 09 18:07:32 EDT 2025
Powered by FUDForum. Page generated in 0.04028 seconds
