Home » Eclipse Projects » Eclipse Platform » updating from a different branch than the local project
updating from a different branch than the local project [message #249239] Fri, 04 June 2004 03:53 Go to next message
Originally posted by: sunay.yaldiz.gentleware.com
I have a big problem about CVS and I looked through the help but could
not find what is useful for me. My problem is this: I have some
projects whose CVS sources resided on main branch. But a few days ago,
the main branch is tagged as "releaseXX" and a new branch was created(by
other project members). Now the branch from where I have to
update/commit etc are this new branch "releaseXX", and I could not find
out how to set my existing project properties so that in case I say
update/commit, it uses the new branch "releaseXX", no more the main branch.
Thanks for any help,
Sunay
Re: updating from a different branch than the local project(Eclipse 3.0 M8) [message #249244 is a reply to message #249239] Fri, 04 June 2004 04:05 Go to previous messageGo to next message
Sunay Yaldiz wrote:
> Hello,
> Sunay
Sorry, I forgot to say I am using Eclipse 3.0 M8.
Sunay
Re: updating from a different branch than the local project [message #249573 is a reply to message #249239] Fri, 04 June 2004 11:23 Go to previous messageGo to next message
Originally posted by: eclipse.rizzoweb.com
Sunay Yaldiz wrote:
> Hello,
You just have to select your Project, right-click and choose "Replace
With > Another Branch"
That will bring up a dialog window allowing you to choose another branch
as the source of your project. If this is the first time you are using
the branch, you will probably have to use the "Configure Tags" button in
that window to make Eclipse recognize the branches you are interested in.
Search the Eclipse Help for lots of information on these tasks.
HTH,
Eric
Re: updating from a different branch than the local project [message #249826 is a reply to message #249573] Fri, 04 June 2004 20:19 Go to previous messageGo to next message
Originally posted by: ed.burnette.REMOVE.THIS.sas.com
With the newer Eclipse 3 builds you can also Update from any arbitrary
branch (so there's no need to replace files, just merge them). This is
available from the dialog you get now with Team > Update.
Ed Burnette, co-author, Eclipse in Action
www.eclipsepowered.org
"Eric Rizzo" <eclipse@rizzoweb.com> wrote in message
news:c9q3m8$kqd$1@eclipse.org...
Re: updating from a different branch than the local project [message #251050 is a reply to message #249826] Wed, 09 June 2004 11:35 Go to previous message
Thanks for the answers.
I did as Ed told. I installed 3.0 RC1(I had to do it one day:) and it
has the new CVS features that I needed.
Sunay
Previous Topic:search results in help window (3.0RC1)
Next Topic:LOMBOZ J2EE plugin usage and problems
Current Time: Sat Jul 26 13:15:32 EDT 2025
Powered by FUDForum. Page generated in 0.04994 seconds
