Home » Language IDEs » Java Development Tools (JDT) » Step-in in Europa
Step-in in Europa [message #249170] Thu, 01 November 2007 12:06 Go to next message
I had some issues with the Java debugging, specifically the step in, which
was different in Eclipse 3.2 (or, I am missing something)
1. I can't manage to step in some JDK methods, like:
String str = "";
if (new java.util.Random().nextBoolean(())
str += "b";
I can't step inside the nextBoolean(), ando also I can't the StringBuilder
operations that i was expecting to happen for the string concatenation
(obviously when the specific codepath is taken).
I have no filters set for the step-in in preferences, and even if I set
the filter only for java.lang.ClassLoader, the same thing happens.
2. In Eclipse 3.2, when I stepped inside methods, happened something like
this:
1. ...
2. someMethod();
3. someOtherMethod();
4. ...
5. void someMethod() {
6. someOperation();
7. }
supposing I am in (2); I click F5, and I go to (4).
now, if I don't click F5 another time, I return back to (3)!
this is quite annoying.
Am I missing something? Are these some defaults which I can change?
My system is Windows XP/Eclipse Europa.
Thanks!
Saverio M.
Errata [message #249175 is a reply to message #249170] Thu, 01 November 2007 12:20 Go to previous messageGo to next message
Originally posted by: 1.2.3
I made a mistake in writing:
> like this:
> 1. ...
> 2. someMethod();
> 4. ...
> 6. someOperation();
> 7. }
this is happening in Europa.
the order is: (2) -> F5, (5) -> F6, (3).
I was expecting instead:
(2) -> F5, (5) -> F6, (6).
Saverio M.
Re: Step-in in Europa [message #249188 is a reply to message #249170] Thu, 01 November 2007 18:42 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Saverio M." <saverio.pub@inbox.com> wrote in message
news:561fa15ac922f8d651ef2d4ab9bf9f9d$1@www.eclipse.org...
> String str = "";
> str += "b";
> StringBuilder operations that i was expecting to happen for the string
> concatenation (obviously when the specific codepath is taken).
Maybe you need to link to the source code of the JRE again?
Re: Step-in in Europa [message #249278 is a reply to message #249188] Mon, 05 November 2007 12:26 Go to previous messageGo to next message
>> String str = "";
>> str += "b";
The source code is linked (I can open the Random class with F3); even if
it wasn't, I should have received the window "source code not found".
Thanks, anyway!
Saverio
Re: Step-in in Europa [message #249308 is a reply to message #249278] Mon, 05 November 2007 19:31 Go to previous messageGo to next message
>>> which was different in Eclipse 3.2 (or, I am missing something)
>>> String str = "";
>>> str += "b";
>>> string concatenation (obviously when the specific codepath is taken).
> Thanks, anyway!
> Saverio
Hi Saverio. In order to debug into the Java system classes, you need to
be using the JRE that ships as part of the JDK. On my Windows system,
its in "C:\Program Files\Java\jdk1.6.0\jre". This version of the JRE is
compiled with debug symbols, which the standard JRE is not. It is
possible to link the Java source code so it is visible with F3 but still
not be able to debug into the Java system classes. Hope this helps. Mark
Re: Step-in in Europa [message #249325 is a reply to message #249308] Tue, 06 November 2007 06:48 Go to previous message
>>>> String str = "";
>>>> str += "b";
It worked! Thank you very much.
Saverio
Previous Topic:Expressions watch
Next Topic:How to modify eclipse code?
Current Time: Wed Nov 05 21:07:55 EST 2025
Powered by FUDForum. Page generated in 0.04066 seconds
