Home » Language IDEs » Java Development Tools (JDT) » Is it me or is it a compiler error????
Is it me or is it a compiler error???? [message #248869] Wed, 17 October 2007 17:01 Go to next message
Originally posted by: kwarner.uneedspeed.net
I'm having a strange problem. I index into an array three different but equivalent ways. Some ways work -- one way fails with an out of bounds error. Let me attempt to explain --
This is the orignial code I am trying to simplfy and it works fine -- sy, sxL and sxR are properly initialized in earlier code.
This works just fine
desPixels[y + xL] = srcPixels[(sy * imageW) + sxL]; desPixels[y + xR] = srcPixels[(sy * imageW) + sxR];
This form also works
sy *= imageW;
tempL = sy + sxL;
tempR = sy + sxR;
desPixels[y + xL] = srcPixels[tempL];
desPixels[y + xR] = srcPixels[tempR];
This form works too
sy *= imageW;
desPixels[y + xL] = srcPixels[sy + sxL];
desPixels[y + xR] = srcPixels[sy + sxR];
This form DOES NOT WORK <<<<<<<< out of bounds error
sy *= imageW;
sxL = sy + sxL;
sxR = sy + sxR;
desPixels[y + xL] = srcPixels[sxL];
desPixels[y + xR] = srcPixels[sxR];
I just don't see the problem. Is something being optimized away? Or am I just going cross eyed?
DemonDuck
Re: Is it me or is it a compiler error???? [message #248874 is a reply to message #248869] Wed, 17 October 2007 17:11 Go to previous messageGo to next message
Sorry --
Eclipse 3.2.2; Windows 2000 SP4; Java 1.5.0.9
DemonDuck wrote:
> sy *= imageW;
> tempL = sy + sxL;
> tempR = sy + sxR;
> This form works too
> sy *= imageW;
> sy *= imageW;
> sxL = sy + sxL;
> sxR = sy + sxR;
> DemonDuck
Re: Is it me or is it a compiler error???? [message #248879 is a reply to message #248869] Wed, 17 October 2007 19:10 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Is this in a loop of some kind that it fails?
If it is in a loop, you are changing sxL and sxR so that on the next
iteration of the loop they would have a new value when being added to
sy. Unless you reset sxL and sxR on each iteration. The previous forms
were not changing sxL and sxR so that on each iteration of the loop they
have the same value.
Also you are changing sy each time in the loop too. Is it reset on each
iteration of the loop so that sy*=imageW results in a good value?
> sy *= imageW;
> sxL = sy + sxL;
> sxR = sy + sxR;
> DemonDuck
Rich Kulp
Re: Is it me or is it a compiler error???? [message #248883 is a reply to message #248879] Wed, 17 October 2007 19:20 Go to previous message
I'm so embarassed! It's in a double for loop and sxL and sxR are outside
the inter loop. Sometimes I get so tired I can't see the code...
Thanks for the kick in the butt....
Rich Kulp wrote:
>> sy *= imageW;
>> sxL = sy + sxL;
>> sxR = sy + sxR;
>> DemonDuck
Previous Topic:[Quick Assist] Quick assist fails in else-if expression
Next Topic:How to add a new class to a package
Current Time: Tue Nov 04 19:17:22 EST 2025
Powered by FUDForum. Page generated in 0.03597 seconds
