Home » Language IDEs » Java Development Tools (JDT) » prevent build/selective builds
prevent build/selective builds [message #24441] Thu, 15 May 2003 08:12 Go to next message
Originally posted by: benjamin.walther.sunrise.net
Can you prevent do a full clean and build when you change project
properties, e.g. add a jar library?
Can I build just a package tree and not the whole project?
Thanks for help
Ben
Re: prevent build/selective builds [message #25070 is a reply to message #24441] Thu, 15 May 2003 14:13 Go to previous message
Originally posted by: jed_anderson.us.ibm.com
Ben,
No. If you add a jar to the build path, you may change the definition
of a class. For example, if a1.jar contains com.example.A is put on the
classpath before a2.jar, which also contains com.example.A, you can
potentially change the definition of A.
The incremental builder (which normally runs when you save a file) only
builds what needs to be built, but full builds work on projects.
jkca
Ben wrote:
> Thanks for help
> Ben
Previous Topic:unavailable local variables when debugging
Next Topic:Import JBuilder 5/6 to Eclipse
Current Time: Fri Jul 25 00:38:39 EDT 2025
Powered by FUDForum. Page generated in 0.05626 seconds
