Home » Archived » BIRT » Getting the row count
Getting the row count [message #248370] Tue, 17 July 2007 10:02 Go to next message
Originally posted by: andy.nospam.com
I'm using Birt 2.2.
In the Initialize section of the script, I have added
rwcnt = 0;
In the onFetch section of my data set I have
rwcnt += 1;
and then I am using rwcnt in the visibility section to hide or show
different parts of the report if no data is returned.
However when I edit the data set and try to preview the results I get the
following error:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.2.0.v200706221
Error Code:data.engine.BirtException
Error Message:A BIRT exception occurred: Error evaluating Javascript
expression. Script engine error: ReferenceError: "rwcnt" is not defined.
(DataSet[PDI].__bm_onFetch#2)
Script source: DataSet[PDI].__bm_onFetch, line: 1, text:
__bm_onFetch(). See next exception for more information.
Error evaluating Javascript expression. Script engine error: ReferenceError:
"rwcnt" is not defined. (DataSet[PDI].__bm_onFetch#2)
__bm_onFetch()
Am I doing this right? It seems to work in thje report itself, but I need to
preview the data. Is there another way of doing this?
Andy
Re: Getting the row count [message #248434 is a reply to message #248370] Tue, 17 July 2007 12:24 Go to previous messageGo to next message
Andy,
Putting this in the data set script is probably not what you want, as
currently the data set may run more than once.
If it is only tied to one report element then this approach is fine.
Can you post your report?
Jason
Andy wrote:
> I'm using Birt 2.2.
> rwcnt = 0;
> rwcnt += 1;
> following error:
> __bm_onFetch()
> Andy
Re: Getting the row count [message #248447 is a reply to message #248434] Tue, 17 July 2007 12:43 Go to previous messageGo to next message
Jason,
the report is enclosed.
Andy
"Jason Weathersby" <jasonweathersby@alltel.net> wrote in message
news:f7iqdm$5pm$1@build.eclipse.org...
> Andy,
> Jason
> Andy wrote:
>> I'm using Birt 2.2.
>> rwcnt = 0;
>> rwcnt += 1;
>> following error:
>> ReferenceError:
>> __bm_onFetch()
>> to
>> Andy
Re: Getting the row count [message #248466 is a reply to message #248447] Tue, 17 July 2007 13:50 Go to previous messageGo to next message
Andy,
Set the rwcnt=0 in the beforeOpen of the dataset.
Take a look at the attached example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.14"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.2.0.v20070620 Build &lt;2.2.0.v20070626-1003></property>
<property name="units">in</property>
<property name="comments">Copyright (c) 2007 &lt;&lt;Your Company
Name here>></property>
<html-property name="description">Creates a blank report with no
predefined content.</html-property>
<text-property name="displayName">Blank Report</text-property>
<property name="iconFile">/templates/blank_report.gif</property>
<parameters>
<scalar-parameter name="ordernumber" id="8">
<property name="valueType">static</property>
<property name="dataType">integer</property>
<property name="controlType">text-box</property>
<property name="defaultValue">10101</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="6">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="7">
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<method name="beforeOpen"><![CDATA[rwcnt = 0;]]></method>
<method name="onFetch"><![CDATA[rwcnt++;]]></method>
<list-property name="parameters">
<structure>
<property name="name">param_1</property>
<property name="paramName">ordernumber</property>
<property name="nativeName"></property>
<property name="nativeDataType">4</property>
<expression name="defaultValue">10101</expression>
<property name="isOptional">false</property>
<property name="isInput">true</property>
<property name="isOutput">false</property>
</structure>
</list-property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
where ordernumber = ?</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:DataSetParameters>
<design:parameterDefinitions>
<design:inOutMode>In</design:inOutMode>
<design:attributes>
<design:name></design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:nullability>Unknown</design:nullability>
<design:uiHints/>
</design:attributes>
<design:inputAttributes>
<design:elementAttributes>
<design:defaultScalarValue>10101</design:defaultScalarValue >
<design:optional>false</design:optional>
<design:masksValue>false</design:masksValue>
<design:uiHints>
<design:promptStyle>TextField</design:promptStyle>
</design:uiHints>
</design:elementAttributes>
</design:inputAttributes>
</design:parameterDefinitions>
</design:DataSetParameters>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="crosstab" id="4">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab-cell" id="5">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="9">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="38"/>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<header>
<row id="10">
<list-property name="visibility">
<structure>
<property name="format">all</property>
<expression name="valueExpr">if( rwcnt == 0 ){
true;
}else{
false;
}</expression>
</structure>
</list-property>
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="13">
<label id="14">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="15">
<label id="16">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="17">
<label id="18">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="19">
<label id="20">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="24">
<data id="25">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="26">
<data id="27">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="28">
<data id="29">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="30">
<data id="31">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
</row>
</footer>
</table>
<label id="43">
<structure>
<expression name="valueExpr">if( rwcnt > 0 ){
true;
}else{
false;
}</expression>
</structure>
</list-property>
<text-property name="text">No Rows to Display</text-property>
</label>
<data id="45">
<structure>
<property name="name">Column Binding</property>
<expression name="expression">rwcnt;</expression>
<property name="dataType">any</property>
</structure>
</list-property>
<property name="resultSetColumn">Column Binding</property>
</data>
</body>
</report>
Andy wrote:
> Jason,
> Andy
>> Andy,
>> Jason
>> Andy wrote:
>>> I'm using Birt 2.2.
>>> rwcnt = 0;
>>> rwcnt += 1;
>>> following error:
>>> ReferenceError:
>>> __bm_onFetch()
>>> to
>>> Andy
Re: Getting the row count [message #248601 is a reply to message #248466] Wed, 18 July 2007 08:52 Go to previous message
That works!
Thanks Jason.
news:f7ive8$e7q$1@build.eclipse.org...
> Andy,
> Jason
> id="1">
> <property name="comments">Copyright (c) 2007 &lt;&lt;Your Company Name
> here>></property>
> <parameters>
> </structure>
> </scalar-parameter>
> </parameters>
> <data-sources>
> <oda-data-source
> id="6">
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orderdetails
> <model:DesignValues
> <design:attributes>
> <design:uiHints/>
> <design:uiHints>
> </design:uiHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> <design:attributes>
> <design:usageHints>
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> <structure>
> <expression
> </structure>
> </list-property>
> <column id="38"/>
> <column id="39"/>
> <column id="40"/>
> <column id="41"/>
> <column id="42"/>
> <header>
> <row id="10">
> <structure>
> true;
> }else{
> false;
> }</expression>
> </structure>
> </list-property>
> <cell id="11">
> <label id="12">
> <text-property
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> <text-property
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> <text-property
> </label>
> </cell>
> <cell id="17">
> <label id="18">
> <text-property
> </label>
> </cell>
> <cell id="19">
> <label id="20">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="21">
> <cell id="22">
> <data id="23">
> <property
> </data>
> </cell>
> <cell id="24">
> <data id="25">
> <property
> </data>
> </cell>
> <cell id="26">
> <data id="27">
> <property
> </data>
> </cell>
> <cell id="28">
> <data id="29">
> <property
> </data>
> </cell>
> <cell id="30">
> <data id="31">
> <property
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="32">
> <cell id="33"/>
> <cell id="34"/>
> <cell id="35"/>
> <cell id="36"/>
> <cell id="37"/>
> </row>
> </footer>
> </table>
> <label id="43">
> <structure>
> true;
> }else{
> false;
> }</expression>
> </structure>
> </list-property>
> </label>
> <data id="45">
> <structure>
> </structure>
> </list-property>
> </data>
> </body>
> </report>
> Andy wrote:
>> Jason,
>> Andy
>>> Andy,
>>> Jason
>>> Andy wrote:
>>>> I'm using Birt 2.2.
>>>> rwcnt = 0;
>>>> rwcnt += 1;
>>>> the
>>>> following error:
>>>> defined.
>>>> ReferenceError:
>>>> __bm_onFetch()
>>>> need to
>>>> Andy
Previous Topic:NLS Packs for 2.2.0 version still unreleased
Next Topic:Using "style" in a table of a Library
Current Time: Thu Jul 17 19:41:15 EDT 2025
Powered by FUDForum. Page generated in 0.08751 seconds
