Home » Language IDEs » Java Development Tools (JDT) » Java version mismatch in org.eclipse.jdt.compiler.tool bundle?
Java version mismatch in org.eclipse.jdt.compiler.tool bundle? [message #248368] Thu, 04 October 2007 11:59 Go to next message
Hello everyone,
On my Linux platform in which I have Eclipse 3.3 installed, I am seeing
periodic failures when I run test workbenches in the resolution of the
bundle "org.eclipse.jdt.compiler.tool_1.0.0.v_771". Upon examining this
plug-in's MANIFEST.MF file, I find that it has a
RequiredExecutionEnvironment of "JavaSE-1.6". This would seem to directly
conflict with the assertion on the main Eclipse download page that the "Java
5 JRE is recommended" for europa downloads. I obviously only have Java 5
(JRE 1.5.0_12) installed.
Any thoughts on this?
-Pete
Re: Java version mismatch in org.eclipse.jdt.compiler.tool bundle? [message #248373 is a reply to message #248368] Thu, 04 October 2007 12:08 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Pete,
I guess the respective bundles/fragments contribute optional
functionality that makes only sense if you're running a 1.6 JRE.
It doesn't require you to actually have a 1.6 JRE but when you have it
you can use its features (like APT).
Cheers
/Eike
Pete Ellis schrieb:
> Hello everyone,
> -Pete
Re: Java version mismatch in org.eclipse.jdt.compiler.tool bundle? [message #248379 is a reply to message #248368] Thu, 04 October 2007 12:59 Go to previous messageGo to next message
JRE 1.5 is fine if you don't use 6.0 features.
org.eclipse.jdt.compiler.tool and org.eclipse.jdt.compiler.apt are about
the jsr199 and the jsr269 which both require a JRE1.6. This is why are
are not resolved if you only use a JRE1.5.
This will not prevent you from using Eclipse.
Hope this clarify the error.
Olivier
Re: Java version mismatch in org.eclipse.jdt.compiler.tool bundle? [message #248400 is a reply to message #248368] Thu, 04 October 2007 15:35 Go to previous messageGo to next message
Originally posted by: wharley.bea.com
"Pete Ellis" <pellis@wwtechgroup.com> wrote in message
news:fe32ia$ncm$1@build.eclipse.org...
> Hello everyone,
Olivier and Eike's explanations are correct.
For more info on the underlying issue of how plugins indicate failure to
load, see (and vote for, if you choose)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=174515 .
Re: Java version mismatch in org.eclipse.jdt.compiler.tool bundle? [message #248404 is a reply to message #248379] Thu, 04 October 2007 16:03 Go to previous message
Olivier Thomann wrote:
> Pete Ellis a
Previous Topic:How to 'copy' MethodDeclaration from one CompilationUnit to another
Next Topic:Re: Dynamic output path
Current Time: Tue Jul 22 12:05:41 EDT 2025
Powered by FUDForum. Page generated in 0.04420 seconds
