Home » Newcomers » Newcomers » birt 2.2.1 and weblogic 8.1
birt 2.2.1 and weblogic 8.1 [message #248337] Fri, 08 February 2008 02:55
Originally posted by: j.dott.dpcom.de
we are sucessfully using birt 2.1 with weblogic 8.1 and would like
to upgrade to birt 2.2.1.
After having deployed birt 2.2.1 a call of the report url leads to
the following exception:
java.lang.NoClassDefFoundError
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:2 74)
at java.lang.Class.newInstance0(Class.java:308)
at java.lang.Class.newInstance(Class.java:261)
weblogic.servlet.internal.ServletStubImpl$ServletInitAction. run(ServletStubImpl.java:1026)
weblogic.security.acl.internal.AuthenticatedSubject.doAs(Aut henticatedSubject.java:321)
weblogic.security.service.SecurityManager.runAs(SecurityMana ger.java:121)
weblogic.servlet.internal.ServletStubImpl.createServlet(Serv letStubImpl.java:904)
weblogic.servlet.internal.ServletStubImpl.createInstances(Se rvletStubImpl.java:883)
weblogic.servlet.internal.ServletStubImpl.prepareServlet(Ser vletStubImpl.java:822)
weblogic.servlet.internal.ServletStubImpl.getServlet(Servlet StubImpl.java:535)
weblogic.servlet.internal.ServletStubImpl.invokeServlet(Serv letStubImpl.java:373)
at weblogic.servlet.internal.TailFilter.doFilter(TailFilter.jav a:28)
weblogic.servlet.internal.FilterChainImpl.doFilter(FilterCha inImpl.java:27)
at org.eclipse.birt.report.filter.ViewerFilter.doFilter(Unknown Source)
weblogic.servlet.internal.WebAppServletContext$ServletInvoca tionAction.run(WebAppServletContext.java:6724)
weblogic.servlet.internal.WebAppServletContext.invokeServlet (WebAppServletContext.java:3764)
weblogic.servlet.internal.ServletRequestImpl.execute(Servlet RequestImpl.java:2644)
at weblogic.kernel.ExecuteThread.execute(ExecuteThread.java:219 )
at weblogic.kernel.ExecuteThread.run(ExecuteThread.java:178)
Unfortunately the stack trace does not say which class cannot be found.
Does anyone
have a solution to this problem? Does birt 2.2.1 pricipally work with
weblogic 8.1?
Thank you for your reply
Juergen
Previous Topic:how eclipse with -configuration parameter ???
Next Topic:Getting registry of all the Actions which are in the plugin
Current Time: Sun Jul 27 06:32:13 EDT 2025
Powered by FUDForum. Page generated in 0.08122 seconds
