Home » Language IDEs » Java Development Tools (JDT) » Example of org.eclipse.ui.editors.templates extension point?
Example of org.eclipse.ui.editors.templates extension point? [message #248174] Wed, 26 September 2007 20:41 Go to next message
Originally posted by: doddsie.pacbell.net
I would like to create my own set of templates that you can find at Preferences
> Java > Editor > Templates AND distribute them with out the user having
to import them manually.
Is there a way to import my templates with no manual action from the developer/user?
I found this extension point org.eclipse.ui.editors.templates but the documentation
is not all that clear what is needed. Seems like this would work.
Is there a "simple" example out there of this extension point to get me bootstraped?
Ideally, I could have my plugin look for an xml file in a special location
and then load them when the user intends to use the templates.
Dave
Re: Example of org.eclipse.ui.editors.templates extension point? [message #248211 is a reply to message #248174] Thu, 27 September 2007 11:45 Go to previous message
David ddodd wrote:
> Preferences
> developer/user?
> documentation is not all that clear what is needed. Seems like this
> would work.
> me bootstraped?
> location and then load them when the user intends to use the templates.
The simplest way is to put the templates in a plug-in using the
org.eclipse.ui.edtiors.templates extension point:
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.isv/reference/extension-points/org_eclipse_ui_e ditors_templates.html
This allows to specify/include the templates in an XML file.
Dani
> Dave
Previous Topic:TDD Symposia on Eclipse Summit Europe
Next Topic:Java formatter
Current Time: Sat Jul 12 23:07:28 EDT 2025
Powered by FUDForum. Page generated in 0.04625 seconds
