Problems Loading Custom Driver in Report Viewer in WebSphere Application Server [message #248071] |
Mon, 16 July 2007 08:20  |
When I try and "deploy" a report, which uses my custom ODA Runtime
Driver built using the wizards in BIRT 2.2, to the BIRT Report Viewer
running in WebSphere Application Server 6.0.2, I get the same error
("Cannot get ODA data source driver helper") that I reported previously
when trying to use a hand-crafter driver built using BIRT 2.1.2.
I have followed the instructions to debug dependencies using the OSGI
console etc. and have sorted out those problems, so it is something else.
I have also tried a brand new Runtime Driver generated using the 2.2
Wizard. I can build a report and preview it ok in the Eclipse
environment, but when I import the generated driver into the plugins
folder of the Report Viewer, export an EAR and load that EAR into
WebSphere Application Server, and then try and view my report, I don't
get any data and in the SystemOut.log file I find the following:
[16/07/07 13:05:46:576 BST] 00000035 odaconsumer E
org.eclipse.birt.data.engine.odaconsumer.Driver doGetDriverManifest
Cannot process data source extension configuration.
java.lang.IllegalArgumentException:
com.ibm.sr.birt.runtime
org.eclipse.datatools.connectivity.oda.util.manifest.Manifes tExplorer.getExtensionManifest(ManifestExplorer.java:163)
org.eclipse.birt.data.engine.odaconsumer.Driver.doGetDriverM anifest(Driver.java:147)
org.eclipse.birt.data.engine.odaconsumer.Driver.findDataSour ceExtensionConfig(Driver.java:123)
org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverExt ensionConfig(Driver.java:78)
org.eclipse.birt.data.engine.odaconsumer.Driver.getExtension Config(Driver.java:60)
org.eclipse.birt.data.engine.odaconsumer.Driver.getDriverHel per(Driver.java:93)
org.eclipse.birt.data.engine.odaconsumer.DriverManager.getDr iverHelper(DriverManager.java:86)
org.eclipse.birt.data.engine.odaconsumer.ConnectionManager.o penConnection(ConnectionManager.java:136)
org.eclipse.birt.data.engine.executor.DataSource.newConnecti on(DataSource.java:134)
org.eclipse.birt.data.engine.executor.DataSource.open(DataSo urce.java:121)
I called the new project com.ibm.sr.birt.runtime, following an earlier
suggestion by Linda Chan.
Here is the MANIFEST.MF file for the generated driver:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: %plugin.name
Bundle-SymbolicName: com.ibm.sr.birt.runtime; singleton:=true
Bundle-Version: 1.0.0
Bundle-ClassPath: .,
src
Bundle-Activator: com.ibm.sr.birt.runtime.Activator
Bundle-Vendor: IBM
Bundle-Localization: plugin
Export-Package: com.ibm.sr.birt.runtime.impl
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.datatools.connectivity.oda;bundle-version="3.1.0 ",
org.eclipse.datatools.connectivity.oda.profile;bundle-versio n= "3.0.4"
Eclipse-LazyStart: true
Is the problem in the way that I am adding the driver to the Report
Viewer? Is there anything else I have to do apart from import the driver
into the plugins folder?
John Colgrave
Re: Problems Loading Custom Driver in Report Viewer in WebSphere Application Server [message #248103 is a reply to message #248071] |
Mon, 16 July 2007 11:09   |
John,
Are the standard data sources working in this situation?
Can you build a report that uses flatfile driver and see if it works?
Jason
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> src
> Bundle-Vendor: IBM
> John Colgrave
Re: Problems Loading Custom Driver in Report Viewer in WebSphere Application Server [message #248381 is a reply to message #248346] |
Tue, 17 July 2007 11:17   |
--------------020608010200020605080604
John,
I am still looking at this, but can you change an entry in your manifest
file?
Use this line for required bundles instead of the one that is produced
by the wizard.
Require-Bundle: org.eclipse.core.runtime;bundle-version="[3.2.0,4.0.0)
",org.eclipse.datatools.connectivity.oda;bundle-version="[3.1.0,4.0.0
)" ,org.eclipse.datatools.connectivity.oda.profile;bundle-versi on= "[3.
0.4,4.0.0)";resolution:=optional
Also export the plugin using the export wizard on the overview tab of
the manifest editor. If you would like you can use the attached plugin.
It is your code with the added manifest change.
Jason
> Jason Weathersby wrote:
>> John,
>> The problem happens in the Web Viewer on Tomcat as well. I am still
>> investigating this, but this looks like a bug.
> Jason,
> Thanks for the update. I was wondering if it was a WebSphere-specific
> classloader issue, or the fact that WAS 6.0.2 uses a 1.4.2 JRE, but if
> it is failing on Tomcat as well it looks like something more general.
> One thing I have noticed, I don't know if it is relevant, is that the
> wizard generates the Activator class in one package and the rest of the
> code in a different package. None of the sample plug-ins I have looked
> at use separate packages. Do both packages need to be exported?
> WAS 6.0.2 does not use OSGi natively so I assume BIRT/ODA is completely
> responsible for the OSGi configuration, which I guess is not the case in
> the Eclipse environment. Could that be relevant? I don't know about Tomcat.
> John
Content-Type: application/octet-stream;
name="com.ibm.sr.birt.runtime_1.0.0.jar"
Content-Disposition: attachment;
filename="com.ibm.sr.birt.runtime_1.0.0.jar"
UEsDBAoAAAAAAAFa8TYAAAAAAAAAAAAAAAAJAAQATUVUQS1JTkYv/soAAFBL AwQKAAAACAAA
WvE2Iw8+vmIBAAC3AgAAFAAAAE1FVEEtSU5GL01BTklGRVNULk1GjZFPawIx EMXvC/sdglCo
4A7rn1JY8aDiQdAiFXrpocxmRw3NJtskK10/fbOu3XpQ6Clk3szvzUvWqMSO rIveyFihVcL6
EIfBVF1VpgXyAzFf8+JzLc8NoaMsmlV1/xPEH/04SuMhe9yWiq0FN9pW1lFu 2VJx6IbBrFSZ
pGh9sWvZg1Z6wZwS9lDIci8UKH9rpW2Vp1oK3rRwnYNIc7AGUmEcmFI5kdOY WaH2kpzHTpwp
/8avo9XbX8pzidZu0B0SBj1reCtMuRNHdNrc9YK25cpEZfXEcrZuayvNUYoT urN7kywMFt+F
Ni7aIP/E/f08IPJChsErfZXCUNQgE6bNHohLUVgCrg218dPG89iEnXTehzCA uDeqM/sPYJ3e
9WiGzq+vpfUQpaiOI1wFOsNboP4vyHO6/wVBYfROyJubeU4Mo8tynbEhq2V5 fqaJLuoTffRF
YxGt8FRtHRqXsOZfw+AHUEsDBAoAAAAAAAFa8TYAAAAAAAAAAAAAAAAEAAAA Y29tL1BLAwQK
AAAAAAABWvE2AAAAAAAAAAAAAAAACAAAAGNvbS9pYm0vUEsDBAoAAAAAAAFa 8TYAAAAAAAAA
AAAAAAALAAAAY29tL2libS9zci9QSwMECgAAAAAAAVrxNgAAAAAAAAAAAAAA ABAAAABjb20v
aWJtL3NyL2JpcnQvUEsDBAoAAAAAAAFa8TYAAAAAAAAAAAAAAAAYAAAAY29t L2libS9zci9i
aXJ0L3J1bnRpbWUvUEsDBAoAAAAAAAFa8TYAAAAAAAAAAAAAAAAdAAAAY29t L2libS9zci9i
aXJ0L3J1bnRpbWUvaW1wbC9QSwMECgAAAAgAAVrxNg8WysrxAQAAewMAACcA AABjb20vaWJt
L3NyL2JpcnQvcnVudGltZS9BY3RpdmF0b3IuY2xhc3ONkl9PFDEUxU/3LzsO oOCCCLgusAhr
so3xEWOiIIZkQ0jQfTXdoYzV2emm00E+ln8eSHzwA/ihjLfdyZL4AL60vbd3 fuecZn7/+fkL
wDNs11FiaEd6xNVwxDPDh8pYbvLUqpHkryKrLoTVpo4KQ0ubmMsoUeNM8kgb OZ07SfJYpQyN
k/77t0fHH44OGBb6n8SF4IlIY35qjUrjPYbZfZ1mVqR2IJJczqDBsEziPRLv ZabnxHsFlKE2
LrCb/VsNErv2QqXKvmQo7+wOGCr7+kwGKONuiBCzDPN9lcrjfDSU5p0YJtJZ 1JFIBsIoVxfN
iv2oMoYq2TSWobPTd7F1Fit+bsRIftHmM3+dp2eJpDBWXto9Jxe8uYzk2CrK V8cDhsXr9NMb
5+ZhiPtoNsCwFiLAHYZ6NMEwbNwuRf4yq8eO1A7RQpOUY2kP5LnIE293978e KzjVuYnkoXKR
56Y3PecabXJXpv+jhBVUUaOq7qsZMkyW6VyhHj0qrXNUPaed0V7tXmH+mx+9 R2tAOyhtBU0s
0CmcDGHRI5h7B5pYKnDLHnVIHfdV0H16hZXuD6xe8+a8qTUirKOBR565NJku mO60TjfOTusm
OiOwU3j8L71D09tEf3IjvYENbBbht3wqUvmO1a9TWs13uaeUfNotf+r8BVBL AwQKAAAACAAB
WvE2ZxBzYNoCAADaBgAALQAAAGNvbS9pYm0vc3IvYmlydC9ydW50aW1lL2lt cGwvQ29ubmVj
dGlvbi5jbGFzc6WVbU/TUBTH/3fPG+NBEBQfUBFhGw9XeZAXQxKCmhCHaEZI MCam627mxa5d
2g7hO/lCEw2JJH4AP5Tx9K50ZVvIjC/a3nvuOb9z/ue06e8/P38BeIKnSUQY 5nSrzmWlzh2b
V6TtcrtpurIuuKw3DL5tmabQXWmZScQYRo60Y40bmlnje5UjOkgiwbBs2TUu dEM2HMGrmqu5
lmU4XPdjj6V7yq2qxnfaNIZU/YN09hqCluwdQ2JDmtLdZIjm8gcMsW2rKjKI YjCLNDJpMAxn
kUSKniVpitfNekXY+1rFEAyjJUvXjAPNlt7eN8bcj9JhyJf61FekEEuVM5kr KZlNVxr8jU1G
25XCKXp1ZV6c6KLh+TtJ3GRY6VP6XlULIhmGvPM2mWGid0aGQUe4W40GlemK E5dh3K8tNAJV
V1K/8BjtdmCI64blUFMSFy2nLlPTB2rC3RWu9pwKZ9gNs8uuLc1aMV/qd7Ye o9zGFZN4xLBw
ZfM7QjKYwZw37hzDeq7vxKERep0YqLao+6cNcbkbviR69Uzx+W1T2KcM2/+l WUFI6RLD9JVK
lWMGixikkXpN1048k5o9jWKHJkPxdUnzS9mWYVQ0/RO9bGWraevipfTe5+G2 ziWvZDygbyJK
V5yuiPdp0EedoXVa3Qdot0F25lkLZ8gWoj8w9I12EYzQfYhigTHEME4RY7hG u2zLG6O0B62v
01kEE7SO0e6GYm6SJULPRCF2iZdR1rtUzZRiTbS8fJa3msQtojDcxp0u6pri UM42MKGKmQ3B
WABjlGhKwe6pxJdhq77sRIfkVolLVCIPyU0Ecu9TSztZXGUB4oXvGPrSUdx6 CBMPMNN42IV5
Rt32kqfPMXNI05j92oHaCulMBzrTyKOgKpjHQhd0wx9F6hyLh2fgncxXIWYq YKYC5mP6B3Qy
F3y9kWin2HJIbCQQu9yj//PqpMcw34cQLECs/Aui2hOxqrzW/gJQSwMECgAA AAgAAVrxNmx7
i77bAwAAgAoAADIAAABjb20vaWJtL3NyL2JpcnQvcnVudGltZS9pbXBsL0Rh dGFTZXRNZXRh
RGF0YS5jbGFzc51VXXPbRBQ9azuR4yoNDQlpC6UphMZ246iloaW4FEjagKkd p3Fqpp1hGFle
XGVkSSOtMvQBXnnllf/AA8xA0qEz8M6PYrgr2Y5ia0qcB1l378fZu+eelf/5 98+/ANzAYwUp
hhXD6Wpmq6v5ntYyPaF5gS3MLtfMrmtp93WhN7iocaFLU0GG4bU9fV/XLN3u aPXWHjeEgkmG
247X0bhhma7PtTblCsexfM1wbJtSzH1TPNectq5VhiAZ1O43/SzHZlirnhRp Y1BVZpi8a9qm
uEeN5E8DUGgyZDacNs8hjWkVUzjLkM4XmlOgE6tQkGWYqZo23wq6Le7t6i2L M8xWHUO3mrpn
ynXPmRHPTJ9htToOtXSEXJyG6Q4XG7H1rXzhdMTkHnxncFcufAUXGW6eEKXe 1geVDHPUTtix
E3gGj+ZOZ/w+Xz1SQ0N4pt0pn85z8tPtcD+wBFFXVvA2w/IR1GPbD1zX8QRv 113u6bL1wRly
uIRpBsUgaMvpyNmNNEEy8o1nvEuqnHTCM1LBPvf8kIMLxzio6XuO1+zHSCqV kQzTjmWcPxbb
9px2YIgtvUuCmaPZjvSSxTVS3leNnZ1FWbYY1TG8mYTT20XBKsPCMNR6YFpt 7uVIyddVvIer
ObyPNQU3Gc4d5VZswTvcU/EBbjFkhRMVM8znKwnt5fAhPlJw59j3IIqpKOOu JE63Al7/luFq
XCWRdsqJkCXck1fvE7lpgkSaWXzGwFZl4oaK+3hAc9Jdl9tthlJSxYirx0VZ kvG5imVJRgkV
eeoCXXDitvGo2iDx8d3nLrF9sacov0aaM12LD9Tnh0N/SgMZTiHt2VEa5Sz0 o3LU7Xj18ci2
7tFL0BxJD/1IxY675/vueiDi/jOya/LX6PNF9z0SxqYpP0VzQ1+ZVckHrtDh 0/RM0JOSnzb6
P5ihZwqSljNkbZI/Re9c8RBq8dofmPmNVimco9+zVAu6TBlcpopFzNLqjSgb r2MOCK15QqVZ
UWSBYufJl6HVhRBdCyPARPF3zPw6AJ4MnfkQUI0SeoBEMt4agXlKngl6Z1/i 0pNDXP57COl6
iLQW5Qxay1LLV8J4Fu+QlQqtd8lKh9YSWXIPuicjO670Gk9lfhna606s69Sg 6+VXYaSHMdYT
MfIojGCUehjp2eIwfQ9jIOkByEoCSDPUALD0EqUnxQNoL3DjBW4f4uPZTw+w Tp5N8pB1gC+O
domm36C57hKRjdhuS4PdvhyLuq8Tj/0Q1TGo44kYtbEwuokYW2NhBIkY9bEw fkjE2H4Vxgin
PyZiPBqrj58SMXZotux/Kn9OrGyEq93/AFBLAwQKAAAACAABWvE2cioCBK0D AAAGCgAAKQAA
AGNvbS9pYm0vc3IvYmlydC9ydW50aW1lL2ltcGwvRHJpdmVyLmNsYXNzrVVt b9tUFH5u29Vu
6pUt69ZSBoyNsbTdcvfCgNIwliYpy0gT1mSVJk0qjnMbPDm2Zd9U2X/iwwCp m0DiIx/4UYhz
7byRwIjaJnLse3LOc57nnON7//zr198B3EFNwxTDNctrcbve4mHA63YgedB2 pd0S3G75Ds8H
9qEINMwwnHthHprcMd0mr9RfCEtqmGVIe0GTC8ux/VDwhilN6XlOyC3PdcnF PrTlS+41TF6M
kRiSlXx2P5+tZferlae7ucJ+MU/G0gC8KgPbbW4y6BmCdW35gGE6tbrHMJPz GkLHWYYlIp0m
0ukwSCvS6S7pOTC8Y0CDTveS7Ypyu1UXQc2sO0Jl8SzT2TMDW627xtlMlCOB aSwaSCJBeeQP
dshwvTRBaYjn2aaQua5ez2V4lBpXs1qatE4DJIJOFDqW8NUi1PAew70JUSoN sx+p4X2GG2+V
MsiZwGUsMiwo7KrXDixRe+lTlS6EQpa8Jjke2M12YMZKM6lJZY3Gbqp+zjk9 K8PGsZEYzlMD
dszOQEUYTUyRWkO0s75P/0jRkQwXh1sTT3HERLN6HslxB4b5KIFrH4iQXB6n Ju5mW9oOb3Uj
eaEjhRsSvx7WZgK3wDWkGQrHQuwBFTq+4wUiMHAbd2K+RTeUpmtR74rH5TuK HtG9Z+BT3GdY
pBxjghien2T4/69c1EDKWqa+H4o8wajZLJstoRpbXB1PnKDtYMPAGtYT2MRX GjIM26fDxcAD
fE0vCvFRTKpCxi/K3unpH8IlJVnkNGwxPDwploE8CjToXebKtGP6PhFVo1I8 AdkhKCL8DYoa
HjHkTwPPwGN8G2+1cfvjai+m/qXrOnboFSh77q2GOKAzoEFi3X/MjDpHGBht EPNyWP726Win
fTveO7dtdcLMxydFWhHFRzSS03SdoUtXBxUdxTp956CGdZ5Wa3RXn9mk8QsW fqKnKZyj3wTd
gSWKvIjzkRXkmezHcbqryDNrr3FhEDYbGeMQI3ag1aUoeAnL5PUuPc/QaiWC yZBFQeu/4fKz
1/jg1QjSlQjpUuzTRVJPH9KlCFwhiaOY93t0R2mtDoGxPhjDVVyLwD7G9TGw m12dU9M/jqDd
HhI51Rf5CW5MTmjjPwiliKpqGG0lY2B3I29q0Bvc/BkLR7g7qNkCNRvYot8c tXir3zgdn+Hz
MaTvu7VffoMv2BG+XDnCw9L6H9DXj7D9Klka4K4QX+AJDdAuRX5HoqtkrxHj p0MKllFGJSqJ
QT5PosLtRhjVvwFQSwMECgAAAAgAAVrxNlFbPKw1AgAAdAUAADQAAABjb20v aWJtL3NyL2Jp
cnQvcnVudGltZS9pbXBsL1BhcmFtZXRlck1ldGFEYXRhLmNsYXNzlZJdTxNB FIbf2X7BtoIg
VKWoVPwojWE0JCYG5aaIaVIKSQmJl7PbSR2y3W1mp438Jy/0Ro0X/gB/lPHs thayYGsvds7H
vPvMOWfm1+8fPwG8QDUHi2HbDbpcOV0eau4obbju+0Z1JVfdnsePhRZdaaQ+ lEbsCyNySDPc
PBMDwT3hd/iRcyZdk0OW4VWgO1y6nuqFkrdJa4LAC7kb+D5J1ECZcx60Ba9f gTJkXytfmT2G
VGXrlCFdC9rSRgr5AnKYY1hsKF82+11H6hPheJJhuRG4wjsVWkXxKJk2H1TI 8LwxW1O7DEsd
acb5WkDyuJY6g/32oyt7RgV+mMMKw85/tnnUFuM/aWSX+YfUHRVbqUf8TC9K M7B6QtUkw7BK
qsbFvFtGK7+zm5CenPdIupJMRQQbDPcLKKFoYwMPcygzbE4cz75WA6kL2MQa HU/MpqC2ZDSo
v1CGBT9ORola3E0hOlxLV4Vxv3MUtuiCaMdWYbPvecMbsltBX7vyQEVB8cpN bEedokw1p+jL
0DudJ0tPgNZ5ijhZRjZT/Qb7CzkWCrRm42QRN2gtDAVYwCJZGhSWSLVMfpqi WzHm2QhjpT8l
GOVLDGvMWCV2kvGSPOtaRjVmFIe7I0bk3cad+Ny7WPs3jX1O0Ham0Eoz1bY3 hbZ+TW2HlEmR
zVdLX3Hvzfp3PLgo0o5RB4R/F6M3htIxOj9CZ+lKHpFnkf94UslWsuTjKSU/ mYn2fgrt6SRa
KklzptAqcbT1B1BLAwQKAAAACAABWvE2SNAjuDgFAACMEgAAKAAAAGNvbS9p Ym0vc3IvYmly
dC9ydW50aW1lL2ltcGwvUXVlcnkuY2xhc3Odlk1QHEUUx18vy+6yLCEfhGCi kUSSLB9hQkgQ
hSABEl3d8LUEDVGT3tkODM5XZmaRVHn16tWr11R5UEtNKVV68WSVV69evXq2 yvJ1z+zuZHY2
NBx2tqf7vV//3+uPN7//9/MvADAGZhoSBM6rlqFoZUNxHaWsOZ7iVE1PM5ii GbaurFSZ8yQN
SQJHt+kOVXRqbipL5W2memlIEbhsOZsKU3XNdplSoR71LEt3FdUyTTTRdjTv iWJVqFIQIAId
xgOD7q5an7oESIFAalozNW+GQFt+cJ1Act6qsCy0QVcOOiBLoLuomWyxapSZ s0bLOiNwvGip
VF+njsbfg86kt6UhcaC4fzBTBNK2w2zqoN/JfLERVslzNHNziuvI3tpVme1p lummoZfAuGSY
SxVa98RgH/MJ19iux2U3TUSgy2XeTduet0xPGD0nx8+ykJNWaxbHmw0ItKu6 5WI0nZvMu8M8
uoACCdzIDxZlV2eVuVXdKzXcp9JwjsDoC9PZ5JSFfugikGO7TK16LFjy64fR gfNfJHBRbv4s
XICuLBAYzMEQDOPy8UTUthnurEInXAYlDaMExg4sJQdXYAyZboiZzBf4unQ4 NSPcIocIEpcM
qcuOZTPHw1RditmO8Rs0aVIDV7x9h+pV1oGhv5GDNGQwWjxeBI6pOqNOwVym Dtp5zEHNKZyq
YKLS3phZRDhdds180afnC6K/s95fqGDQyFmwquLcxaEWuAtZEO6izXf5nLa5 wFTNoDqB4ZZR
GtTbUhqmItLe+CECp/OF1l5cpI/mIgvxSUzzSKiHcQy0lOQ+1hVuIxy6I30E TtTYz9lx8Jpm
7AvmNlGw6IuA63a5AOx61LBxv+9LF4bCtSdugEBfdJ6GB9/xc7iHGTXjV3pD rPSGWOmNWtyL
VR3XuPuRZlZC+6/FVYsVoAfPat3scLdXkzveHnS/26vJKQsP+e3FT2TJcryS zVQC1/KyKmo+
mLo0PMKz3Ij2rulWbRvHWWUJTzrl1aFeJrLA+LQpF8fn8A4YO/CE/sXf0Dwu n7oQI1uyqo7K
bmv8XGfF3T3KQ4BzeLu04a8dfwl+yeDHQz+2sT7jsxPfFPwn+N8+9Axy32Ij AUfwmRKdZ6Eb
nznfAI7CMfzHOgYn0KoH20l8Oykw14UnjkYReYHo9QcDBG+dgj4x80twWh52 pQXsDLwsYK9g
WFHYsLCIgU2GgiP14M7Cq02Iq9jDrTJ70H/vGZz/JkKaD5EyddJrMNBEWsYe Lr5nDy4g6VJx
eOhHyP8EIwkYblCP4JoBLCFrGZO9Egq6J6BncLarMC6Cvob5is7zFv7a4oLe ELB+fzCUwQmx
HLz1OrZ4uFg4m7AzgfzU0JkfYLLBzopeinukHBKbqvNT8CZK5mKxxDdRG1vw e5j8OiJYi92C
UwdZaDd2oafhhnzaPmuRtplQ2jIibdMIkcZ+3gI7K7IVxt6EuVhsMg77hYTa +QC7II/9UkKt
j70Ft+WT8JWE2rcD7Dvy2KcSan1s4SAH6DsJtX0B9l157J6EWh/7HhTlsb9J qL0TYBflsX9I
qPWxS+LKk8T+KaF2JcCuymP/klDrY0uwJo/9W0Lt3QC7Lo/9R0Ktj30fPpDH /iuh9l6A3ZDG
knYJtT72/gG+GsiRFoV+JvhquB9TnFrCTrWAzQY16UP4qAk2AUTYJ9oiBYn0 h2iJOi1Rl/Yx
PHjRB8RDLPvlyAcEGYn9gFCh0kSaDiowkhiSNn+NkCZC6jJ1dRnYwkLK1W3D J03MEfDrb4JE
dc2GdCXqunTxZvwPUEsDBAoAAAAIAAFa8TbFO//KHgYAACYSAAAsAAAAY29t L2libS9zci9i
aXJ0L3J1bnRpbWUvaW1wbC9SZXN1bHRTZXQuY2xhc3OtlktQHFUUhv87zDDD pAMJ5inkAYlk
GELavNQI+AASM5GAQkIkiZJm5mZo7MekuweI7/iOj6hxlyo3unAhVWpVQixj 6UoXVrl16dal
W1eW53YPzdgzpJkqK6T7zu1z//Odcx/n/vrP9z8C2I9P44gwdGRNXVandNm2 5CnVcmSraDiq
zmVVL2jyKLeLmjPGnTiiDOtmlFlF1hQjL49MzfAs9dYz7DetvMyzmlqwuZxT HMUxTc2Ws6Zh
kIk6qzqXZTOnyBlfjKFBn9SV+VFzzmZgGYZGfTJbtCxuONSXyTHU96qG6jzC UJfqHGeIDpg5
nkQdGiUksYahaUg1+HBRn+LWKWVK4wzNQ2ZW0cYVSxW/S51RZ1olF6mh1UXZ w7Amz52T3FEG
KRCGvlTnUM3hLQ0nteTR+SwvOKpp2HFsZji4SrGRnOKPjGMrw77VBbDkOokt aCT3NnUt5Tma
ynSON4Bhu4Q4EpRamgKyyZfZULZpNqIGn3fcH2eTZH+fhJ1oEyP3SGgQI+P+ 5MWymmlToutJ
hXpoZqkx5liqkWfYSB6HlteM190Txz6GzcHu/qKq5biVwP3k2DLnkujGATHZ B4VOpUrnuEA7
LCGNNmH7oISHcIRAlEKBG7SCWqs5L3npSYAmJz6ZNbWibojhfWI4Lbfuaq7u IvMYedw5q2hF
LlT6JQxgkCHhmEs52JCqkgLKm2rkOGW/Y1X+ekSsxyVkcIIm7CKNHXDJV0hN RpgPSejCXjL3
ghxWdHeTVGERc5cxHG+FuGNHJYzgKW8yB82it5Xo42ActBn3LGucNuxioWBa Ds+NFLiliPXq
L9wkTotFWBVxULg5K2EMpxjWkpt+NT/Is6quaAxb/anTFWdaXv5EsOmVExY0 Fi4mJZzDeZpr
EYniiBT44vYlTRZ9pLprZVXfSsjlJFyA4smdUvUKOdEXLudaCTlVAsdFBqkk ZzuKXqDNUaHp
fiDhVLiwZyrUDQkzeN6D7dfMKTqqhfBqzzMxhFz2V3VZk4iAsSWYKHgwA7XD DPwfMANLMPMS
HBS9s6+fjLlieAv87ArL1T0HX5ZwGS9QCHOKPVzUtCRew+txXPlPYfRGSHgD bbSzNG7knWlh
+JaEt/EObSm7OGWXzoZNqUy1AzKJq3g/jvcY1i9/ow3K89yS8IE4AxIFxbI5 9cVxjWHHsplX
Eo+ZFm0GfyOSvXcIiMqa0BTbGZhWLAp/zCxaWX5MFfu70S8i+4Qc2ijiOvof Q4T+UcGgS0NE
HP/03kb9VIbpKdEvmd6M3rH0baz91jVrome927kd6+gpeQZYj2Z6M9yDDWS1 kdpR+rXJlTlA
PcIqcQdbJm7j3m8CSnvLlBK+UgtaK5QecZFpXLrlFrYtEyXd3kPEcdjV2uRZ lbREawcp00oQ
9a4iuJvYthBA6qsaXDt2VSDplEvhrC29iN29LZ8hluglxY6Wz9GUnqBG9MIt eizULbvYTkkH
jpNwhtJ+gtI9RHkbpuSPEOdoWQRtJdcxykXKjYChk+yDEIdKGa5P15GzYF7O 0fjzZQHV+wFR
ia3QKs9LRzAv2ap5oXJUITNeykv7HXRPNMu3sZ8SdGgRDzQ/vIjeFtF4lBqL eDy4HIyyBLT7
U9iOo6UEdOFYlYXheUum012LeGIRTwZVZ8tUk75qEicp8UKVymKF6hFqRdxU EHowFVfKBGO+
YMzHHKGZDcV8Oqh6NQSTymqFam9pV9D+Ok3768xPAc3rZZoJXzPhk47hmXDS ia8DqjdCSKk6
10z6RQjpOTwbTvpccOq/CiGlwl8z6c0Q0guYCifNBkl/CCGlO0XNpD+HkHLk w0mng6S/hZDS
/aRm0t9DSGeghZPqQdI/Qkjp8lIz6Z8hpCYuhZNaQdK/QkjpZlMz6d8hpA4d jKGkcwFS+rs7
Kd2maiVlDSGkl/FiOOlLgfOUrQ8hfaVKSd9bqoCRuqBaa1n5i/jlL1PlpL9G ZFF6d0T7un5B
kuhevYFY60KXaEVz0UW8Odz9Hd7t+xLRM60L7n1nJ7F8WH5HYHsQYSmsZZ1o Ymm0sG7sYjJ2
s4MuR9rz4EfVUYoqgt34iLIWIc01+Jj6xHXvE5f5+r9QSwMECgAAAAgAAVrx NhEAJr7uAgAA
owYAADQAAABjb20vaWJtL3NyL2JpcnQvcnVudGltZS9pbXBsL1Jlc3VsdFNl dE1ldGFEYXRh
LmNsYXNzlZNbU9NAFMf/m95DuApFBRXES4tIUBDk4hVwpk4pjkVmfHEmTXfK MmnSSVIGvo0f
gAd9AUdn/AB+KMezaQ217YA8ZHfPydlf/ueSX7+//wTwCGsJKAyzplPVRamq e65eEq6vu3Xb
F1Wui2rN0t9zr275Re5vcd/YMHwjgSjDwL5xYOiWYVf07dI+N/0E4gzLjlvR uWmJmsf1MsX6
jmN5uunYNoWIA+Ef6U7Z0HMdUIb4mrCF/5whksnuMkTXnTJXEUGPhgSSDP15 YfNCvVri7o5R
sjjDUN4xDWvXcIW0m86ovyc8hrn85ZJaZeircH/dsepVe92h2EBIjkHdPDR5 zReO7SUwzDD/
nzlul43wJkNvCC8YVZI5ksll82c1LPqusCurCVxlGG13v64Lq8zdJK5TlRoQ FaMYl4W5IVGd
oOyujLilYQKTdMmo1bhdZhjv9tUmflXemNJwB3cZkr7TeMkwnOkilCEm7DI/ ZGC51srljRK3
VDBMaxhBujXvnaOabA8poBuD/7hlSeQlXcMDzKg0mPMJPGaYOreHG6444K6G BfmdEQIWDCo/
l938CyVpduCUDjlQDOnwyxvCq1nGUZ7bFX+PQaMX71xuCi9oWJLMIo0XXVGF V6hbVmO+1KJT
d03+Rkgj3TFHs7JUmKRkIvTE6C+TidEA05oiS6ed0R6bPoX6lQ4KNFrjgTON Xlq1RgD60E87
/WoYpKghOkfJuhJgZpoYJXbcxphsYSghg3rRwdgkiQrtgz8w+nHo2inGxk5w 8wS3v7QhZwJk
uhHcRMrTPdwPZGS6wFfII+Pj0wTNthMXWojxkBgPiTQFXeQ2iKmx6GfEEsfR s8z7KBPgBdXs
JZX6VQs8FcJTIfxhF7lb5JGMHil39tn4N8ydaVYDVI70vQ3QE43QEN3TRMdJ wBM6KXRe7JLB
Ep0kKTKQbO/ahxbNkRAcCTUvdcEtNnGK0k771EJTQpoS0p5eila5gLZ8Hq1j PmsX0FYCa/UP
UEsDBAoAAAAIAAFa8TblEgPJ0QAAAIICAAARAAAAcGx1Z2luLnByb3BlcnRp ZXO1UT2LAkEM
7QfmPwS2uSsMYnONCuKWorJbHJbjbFwDTmaJs4L//sYvEO6u05Au7yXvvRTF S8uaAuaxOyu3
+wQf/hNGw+EXjMeb2GuehM7JGZYuEOxJaTrNhNyvF7E+9O2AJZ+UHbe9usRR rsdi47BxyeEx
S/KE3Ex8DMjbgEfFLWtC7SVxoHdpWy5qqJOytO9Yb02XvbOg5JQn33VVQZnt Qn21C6tyBtXN
H5TKJ1JrnuP4k/WAUPo1p2SNjyLkLwljp3HHh3/WXL5xB8L6BrTmB1BLAwQK AAAACAABWvE2
cpyS0KUCAADzDgAACgAAAHBsdWdpbi54bWztl11v2yAUhu8r9T9YSLscWdpp 6iQ7UZu0UqWt
nZSs9wSTDAkDAtw1/37Exh8hRGHZvKv5ysEv5zznzQHjdPpWsOSVKE0Fz8AY fgAJ4VjklG8y
8H358P4GTCeXF+mUYEalJp32Gl7VjyQrN5Tbu8uLJElS8mYI30mqn/VF8wy8 EzmCOTIIalEq
TCDNQU8iBeUmA0JtoEtViY0QTEMsOCfY0FdqtrCJs6jCgEkTJO0Ge3HtlStq qWcMaZ0BLApI
VwXUCq6oMlCV3NDC0hSSwXmlBN50skYlM3OqJUPbJ1QQW0y/EG6HvDmamOUP RVA+E9xYR6rk
XwTKicrAGjHtT7BFvXTOjr2nx/yb9GSpVEISZSjRk/3ZzZPt/nB98aqeRuEn ri/EmPip7wtp
ti+IleRWP5WMZcCo0q/juGXfXIoknMNspRVpo2znBQVU33OsttKgFSONiX6l o6aQ8y24+gcW
hHMMaEE72u+OdNStGG8VERO9BogJLYBdxx5bai7D/+49/69L3B+1tHm/Iilt 2oOsHNkNk8yd
aiZymzdAb7eVBUYMqUaZgcWROvYjtrp9Wg/rj5E/RiE/2m12c7B1B5gb4bDQ N1HQc1HabjjN
7HTDIl/HIRNMC8ROM9/RTaMdlvtzXE/buxind6qBeQObf4B3SQ/21ABvpRqY N64xdiTaoELG
QdfSYcnHn6LI7+wRkyAe0dJOGEft3q7E1CPpqD0YT44flONPwc0Pwe2raU37 20OKbRdvhPLe
mDzq5CqRItzMXIToA7msIZp5v3t+TUcNc68Kv0IP1Jr9gLA5gxI+52jWRndB QNCtDqKdHDAN
t3ad+MqJ9MKvPGSKww5RP89vk66+JFygKycGGdefTn/f5J0XkVEfu1hhq1yG 0GqzH6mj9iv1
F1BLAQIUAwoAAAAAAAFa8TYAAAAAAAAAAAAAAAAJAAQAAAAAAAAAEADtQQAA AABNRVRBLUlO
Ri/+ygAAUEsBAhQDCgAAAAgAAFrxNiMPPr5iAQAAtwIAABQAAAAAAAAAAAAA AKSBKwAAAE1F
VEEtSU5GL01BTklGRVNULk1GUEsBAhQDCgAAAAAAAVrxNgAAAAAAAAAAAAAA AAQAAAAAAAAA
AAAQAO1BvwEAAGNvbS9QSwECFAMKAAAAAAABWvE2AAAAAAAAAAAAAAAACAAA AAAAAAAAABAA
7UHhAQAAY29tL2libS9QSwECFAMKAAAAAAABWvE2AAAAAAAAAAAAAAAACwAA AAAAAAAAABAA
7UEHAgAAY29tL2libS9zci9QSwECFAMKAAAAAAABWvE2AAAAAAAAAAAAAAAA EAAAAAAAAAAA
ABAA7UEwAgAAY29tL2libS9zci9iaXJ0L1BLAQIUAwoAAAAAAAFa8TYAAAAA AAAAAAAAAAAY
AAAAAAAAAAAAEADtQV4CAABjb20vaWJtL3NyL2JpcnQvcnVudGltZS9QSwEC FAMKAAAAAAAB
WvE2AAAAAAAAAAAAAAAAHQAAAAAAAAAAABAA7UGUAgAAY29tL2libS9zci9i aXJ0L3J1bnRp
bWUvaW1wbC9QSwECFAMKAAAACAABWvE2DxbKyvEBAAB7AwAAJwAAAAAAAAAA AAAApIHPAgAA
Y29tL2libS9zci9iaXJ0L3J1bnRpbWUvQWN0aXZhdG9yLmNsYXNzUEsBAhQD CgAAAAgAAVrx
NmcQc2DaAgAA2gYAAC0AAAAAAAAAAAAAAKSBBQUAAGNvbS9pYm0vc3IvYmly dC9ydW50aW1l
L2ltcGwvQ29ubmVjdGlvbi5jbGFzc1BLAQIUAwoAAAAIAAFa8TZse4u+2wMA AIAKAAAyAAAA
AAAAAAAAAACkgSoIAABjb20vaWJtL3NyL2JpcnQvcnVudGltZS9pbXBsL0Rh dGFTZXRNZXRh
RGF0YS5jbGFzc1BLAQIUAwoAAAAIAAFa8TZyKgIErQMAAAYKAAApAAAAAAAA AAAAAACkgVUM
AABjb20vaWJtL3NyL2JpcnQvcnVudGltZS9pbXBsL0RyaXZlci5jbGFzc1BL AQIUAwoAAAAI
AAFa8TZRWzysNQIAAHQFAAA0AAAAAAAAAAAAAACkgUkQAABjb20vaWJtL3Ny L2JpcnQvcnVu
dGltZS9pbXBsL1BhcmFtZXRlck1ldGFEYXRhLmNsYXNzUEsBAhQDCgAAAAgA AVrxNkjQI7g4
BQAAjBIAACgAAAAAAAAAAAAAAKSB0BIAAGNvbS9pYm0vc3IvYmlydC9ydW50 aW1lL2ltcGwv
UXVlcnkuY2xhc3NQSwECFAMKAAAACAABWvE2xTv/yh4GAAAmEgAALAAAAAAA AAAAAAAApIFO
GAAAY29tL2libS9zci9iaXJ0L3J1bnRpbWUvaW1wbC9SZXN1bHRTZXQuY2xh c3NQSwECFAMK
AAAACAABWvE2EQAmvu4CAACjBgAANAAAAAAAAAAAAAAApIG2HgAAY29tL2li bS9zci9iaXJ0
L3J1bnRpbWUvaW1wbC9SZXN1bHRTZXRNZXRhRGF0YS5jbGFzc1BLAQIUAwoA AAAIAAFa8Tbl
EgPJ0QAAAIICAAARAAAAAAAAAAAAAACkgfYhAABwbHVnaW4ucHJvcGVydGll c1BLAQIUAwoA
AAAIAAFa8TZynJLQpQIAAPMOAAAKAAAAAAAAAAAAAACkgfYiAABwbHVnaW4u eG1sUEsFBgAA
AAASABIAPwUAAMMlAAAAAA==
--------------020608010200020605080604--
Re: Problems Loading Custom Driver in Report Viewer in WebSphere Application Server [message #248490 is a reply to message #248381] |
Tue, 17 July 2007 15:14  |
> John,
> file?
> by the wizard.
Jason,
That seems to have fixed the problem, at least once I recompiled my
driver to be compatible with a 1.4.2 JRE.
John
FUDForum. Page generated in 0.08684 seconds
