Home » Language IDEs » Java Development Tools (JDT) » Export compiler warning/error settings?
Export compiler warning/error settings? [message #247884] Wed, 19 September 2007 12:57 Go to next message
Is it possible to export/import the compiler warning/error settings? We'd
like for our entire team to use the same settings, and it'd be easier to
do if we could just export/import these like you can do with the code
formatting settings.
Thanks in advance for your suggestions.
--James
Re: Export compiler warning/error settings? [message #247889 is a reply to message #247884] Wed, 19 September 2007 13:30 Go to previous messageGo to next message
--------------080109070108050504010102
James,
There is a specific request for a category for this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543
Right now you can export all your preference and the compiler ones will
be among them.
> We'd like for our entire team to use the same settings, and it'd be
> easier to do if we could just export/import these like you can do with
> the code formatting settings.
> --James
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
James,<br>
<br>
There is a specific request for a category for this: <br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543">https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543</a><br>
</blockquote>
be among them.<br>
<br>
<br>
James Adams wrote:
<blockquote
cite="mid:5d67daa638c12a42aa89b77916744eac$1@www.eclipse.org"
type="cite">Is it possible to export/import the compiler warning/error
settings?
Re: Export compiler warning/error settings? [message #247909 is a reply to message #247889] Wed, 19 September 2007 17:05 Go to previous messageGo to next message
Originally posted by: wegener.cboenospam.com
You can set these up on a per project basis. They are then saved in a
..settings folder in the root of the project. Checking the .settings folder
into your SCM along with the rest of the project files will make the
settings available automatically if someone checks the full project out.
When setting up new projects, you can copy the .settings folder from an
existing project.
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:fcrmbj$s6p$1@build.eclipse.org...
> James,
> be among them.
> > --James
Re: Export compiler warning/error settings? [message #247914 is a reply to message #247909] Wed, 19 September 2007 18:58 Go to previous messageGo to next message
--------------090808070401000303060900
Dave,
Yes, I should have mentioned that. What would be cool would be a way to
share the settings between projects instead of saving a copy per project...
> existing project.
>> James,
>> be among them.
>>> --James
<html>
<head>
<title></title>
</head>
Dave,<br>
<br>
Yes, I should have mentioned that.&nbsp; What would be cool would be a way
to share the settings between projects instead of saving a copy per
project...<br>
<br>
<br>
Dave Wegener wrote:
<blockquote cite="mid:fcs2um$90p$1@build.eclipse.org" type="cite">
<pre wrap="">You can set these up on a per project basis. They are then saved in a
existing project.
"Ed Merks" <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote in message
<a class="moz-txt-link-freetext" href="news:fcrmbj$s6p$1@build.eclipse.org">news:fcrmbj$s6p$1@build.eclipse.org</a>...
</pre>
<blockquote type="cite">
<pre wrap="">James,
<a class="moz-txt-link-freetext" href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543">https://bugs.eclipse.org/bugs/show_bug.cgi?id=163543</a>
be among them.
James Adams wrote:
</pre>
<pre wrap="">Is it possible to export/import the compiler warning/error settings?
--James
</pre>
</blockquote>
<pre wrap="">
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------090808070401000303060900--
Re: Export compiler warning/error settings? [message #247924 is a reply to message #247914] Wed, 19 September 2007 22:12 Go to previous messageGo to next message
Originally posted by: eclipse5.rizzoweb.com
Ed Merks wrote:
> Dave,
You can do that with Formatter preferences; they have the notion of a
formatting "profile" which would be a nice concept to apply to the
errors/warnings preferences group.
Ed, why don't you enter an enhancement request for it...
Eric
>> existing project.
>>> James,
>>> be among them.
>>>> --James
Re: Export compiler warning/error settings? [message #247929 is a reply to message #247924] Thu, 20 September 2007 01:08 Go to previous message
Eric,
I probably should have but I'm usually reluctant to ask for new things
because the queue is already so big...
Eric Rizzo wrote:
> Ed Merks wrote:
>> Dave,
>> project...
> Eric
>>> folder
>>> out.
>>> existing project.
>>>> James,
>>>> will
>>>> be among them.
>>>>> with
>>>>> --James
Previous Topic:APT and jdt.compiler.tool plugins
Next Topic:Changing Java source in a builder; which mechanism?
Current Time: Wed Jul 16 20:23:22 EDT 2025
Powered by FUDForum. Page generated in 0.05383 seconds
