Home » Modeling » GMF (Graphical Modeling Framework) » Generated diagram code plugin's name
Generated diagram code plugin's name [message #24381] Mon, 21 August 2006 06:15 Go to next message
Originally posted by: zsolt.sandor.gmail.com
Hi everybody!
If I select on a gmfgen file the "Generate diagram code" menu
item, a new package (plugin) will be generated. It's good, but
how can I change the name (location) of the directory where the source
will be generated, because I was not able to find that property...
Zsolti
Re: Generated diagram code plugin's name [message #24421 is a reply to message #24381] Mon, 21 August 2006 07:04 Go to previous messageGo to next message
Hello Zsolt,
Currently you can change only the name of plugin.
Alex Shatalin
Re: Generated diagram code plugin's name [message #24462 is a reply to message #24421] Mon, 21 August 2006 07:16 Go to previous messageGo to next message
Hi!
I can change the Package Name Prefix. But. Until today
it generated the source code into "nts.analysator.diagram"
but today (i don't know, what i changed..) it generates
the code into the plugin "NetworkTrafficSimulator.diagram".
The package structure is ok in the "NetworkTrafficSimulator.diagram",
but I would like to change the name according to the old one,
because I had versioning on that plugin/directory.
Can I do that somehow?
Regards:
Zsolti
Re: Generated diagram code plugin's name [message #24503 is a reply to message #24462] Mon, 21 August 2006 07:30 Go to previous messageGo to next message
Hello Zsolt,
Try changing "Package Name Prefix" property of Gen Editor Generator node
in .gmfgen model.
Alex Shatalin
Re: Generated diagram code plugin's name [message #24584 is a reply to message #24381] Mon, 21 August 2006 08:58 Go to previous message
io,
in the .gmfgen file, change the property named ID of Gen Plugin.
kev.
"Zsolt Sandor" <zsolt.sandor@gmail.com> a
Previous Topic:Question about Taipan example
Next Topic:gmf listener
Current Time: Sun May 11 09:01:29 EDT 2025
Powered by FUDForum. Page generated in 0.03531 seconds
