Re: i wannar select a rectangular area [message #250410 is a reply to message #248063] |
Thu, 28 February 2008 17:48  |
Originally posted by: patricia_shan8.hotmail.com
I'm new to Eclipse, so I haven't tried this yet.
If you are doing enought of this to make it worth while:
Export the file to the file system,and edit it with Microsoft Word.
Then you can use the vertical block select:
Click at the start of the block, to position the insertion point.
From Word help:
(1)Using the mouse:
A vertical block of text (except within a table cell)
Hold down ALT, and then drag over the text.
A graphic
(2)Using the arrow keys:
CTRL+SHIFT+F8, and then use the arrow keys; press ESC to cancel selection
mode
To a vertical block of text
Press Esc to get out of the vertical block selection mode.
Save the document as text.
Import it back into Eclipse.
FUDForum. Page generated in 0.10966 seconds
