Home » Newcomers » Newcomers » Dot notation on a new instance not working
Dot notation on a new instance not working [message #247817] Mon, 04 February 2008 20:00 Go to next message
Originally posted by: cfennelll.gmail.com
Hi all,
I am using eclipse SDK 3.3.1.1
When I create a new String, Int, Socket etc.
The dot notation does not work on the new instance.
Eclipse behaves like it was never created.
Even when I run the code it behaves this way.
I have used eclipse before and have not encountered this issue.
Any ideas?
Thanks in advance!
Re: Dot notation on a new instance not working [message #247848 is a reply to message #247817] Tue, 05 February 2008 01:43 Go to previous messageGo to next message
from your Question is not obvious what is wrong, please provide a
stacktrace.
Martin
Re: Dot notation on a new instance not working [message #247898 is a reply to message #247817] Tue, 05 February 2008 09:05 Go to previous messageGo to next message
cfennell wrote:
> Hi all,
> The dot notation does not work on the new instance. Eclipse behaves like
> Any ideas?
If you want productive answers you'll have to provide better-formed
questions. For example, provide more details about what you are doing,
what you expect to happen, and what you are seeing happen.
Eric
Re: Dot notation on a new instance not working [message #247975 is a reply to message #247898] Tue, 05 February 2008 15:30 Go to previous message
Thanks for the responses, ill take note to provide more detail with future
issues.
A buddy was able to put me in the right direction.
Previous Topic:Launcher unable to locate companion shared library
Next Topic:Key binding for "Terminate" outside of Debug Perspective
Current Time: Fri Jul 18 00:06:25 EDT 2025
Powered by FUDForum. Page generated in 0.14328 seconds
