Home » Language IDEs » AspectJ » Aspect files are not visible in Java Browsing perspective
Aspect files are not visible in Java Browsing perspective [message #24351] Mon, 04 August 2003 12:16 Go to next message
Originally posted by: oesridhar.yahoo.com
Following an example in a book, I created in a package called eg, a
Test.java and a TestAspect.java. I was able to successfully run the
examples within Eclipse. I usually don't like to think in terms of files,
but in terms of classes, methods and now in addition: aspects, pointcuts,
advice etc. As a result I like to use perspectives such as Java Browsing.
After I created the two simple artifacts, the class and the aspect, when I
open the Java Browsing perspective, I see the Test class but not the Test
aspect. Is support for this forthcoming? I am using Eclipse 2.1.1 and the
following plugins: org.eclipse.aspectj_1.1.3 and org.eclipse.ajdt.ui_0.6.3.
Thanks!
--sridhar
Re: Aspect files are not visible in Java Browsing perspective [message #24946 is a reply to message #24351] Tue, 19 August 2003 04:35 Go to previous message
Originally posted by: clemas.uk.ibm.com
Hi Sridhar,
We are about to embark on the piece of work to better integrate aspects
into the Eclipse model - if we can get them into the model then all the
various views within Eclipse will understand them and display them.
regards,
Andy.
Andy Clement
AJDT Development
> Thanks!
> --sridhar
Re: Aspect files are not visible in Java Browsing perspective [message #570225 is a reply to message #24351] Tue, 19 August 2003 04:35 Go to previous message
Hi Sridhar,
regards,
Andy.
Andy Clement
AJDT Development
> Thanks!
> --sridhar
Previous Topic:Disabling debugging aspects
Next Topic:AJDT installation problem
Current Time: Tue Jul 22 13:57:00 EDT 2025
Powered by FUDForum. Page generated in 0.03023 seconds
