Home » Newcomers » Newcomers » Problem running project in console
Problem running project in console [message #247597] Mon, 04 February 2008 00:52 Go to next message
Originally posted by: craigjohansen.hotmail.com
I am running Eclipse SDK 3.2.2 in Ubuntu.
I am running an example (written in C) using the libfann2 library. The
program compiles (called cascade_train.c) fine but there is an error when
I run the program that I compiled:
FANN Error 1: Unable to open configuration file
"../benchmarks/datasets/mushroom.train" for reading.
This error does not occur when I run the program directly in the terminal
by typing: ./cascade_train
When debugging in eclipse, the error occurs when it reaches this point in
the source code:
train_data =
fann_read_train_from_file("../benchmarks/datasets/mushroom.train ");
This is most likely a really simple problem, where Eclipse is inhibiting
the program from finding the folder ../benchmarks/datasets/mushroom.train
Any help would be greatly appreciated.
Craig
Re: Problem running project in console [message #247607 is a reply to message #247597] Mon, 04 February 2008 01:11 Go to previous messageGo to next message
I have imported the files from ../benchmarks/datasets into my workspace
and I have changed the line from:
train_data =
to:
train_data = fann_read_train_from_file("mushroom.train");
And it works fine (so it is not a problem of opening the particular files
in eclipse, just when I ask it to open it outside of the workspace). So,
this method allows the program to run fine in both the eclipse console and
the terminal window.
But, I don't want to have to import every file that I need for it to work.
Any ideas how to fix this properly?
Craig
Re: Problem running project in console [message #247612 is a reply to message #247607] Mon, 04 February 2008 02:38 Go to previous message
Originally posted by: dmsubs.NOSPAM.consertum.com
Try setting CWD
Derek
> train_data =
> to:
> files in eclipse, just when I ask it to open it outside of the
> workspace). So, this method allows the program to run fine in both the
> eclipse console and the terminal window.
> work. Any ideas how to fix this properly?
> Craig
Previous Topic:C Bug
Next Topic:Job scheduling
Current Time: Sat Jul 26 10:04:10 EDT 2025
Powered by FUDForum. Page generated in 0.11466 seconds
