Home » Eclipse Projects » GEF » [zest] Network with pre-defined coordinates
[zest] Network with pre-defined coordinates [message #247595] Wed, 04 March 2009 10:12 Go to next message
is it possible to position nodes with Zest based on pre-defined
coordinates?
I have objects which represents physical locations and which have a name,
a longitude and a latitude. Can I place these locations via zest on their
positions?
If yes, can you point me to a small example on how to do this?
Best regards, Lars
Re: [zest] Network with pre-defined coordinates [message #247615 is a reply to message #247595] Wed, 04 March 2009 11:32 Go to previous messageGo to next message
Update:
I see that I can set the location via:
new GraphNode(g, SWT.NONE, "Test").setLocation(10,10);
Which layout manager would keep the position?
Unfortunately I cannot find any information on zest in
http://help.eclipse.org/ganymede/index.jsp
Best regards, Lars
Re: [zest] Network with pre-defined coordinates [message #247620 is a reply to message #247615] Wed, 04 March 2009 16:34 Go to previous messageGo to next message
after removing the automatic layout manager I can control the points
there the nodes are placed. My question is therefore solved.
Best regards, Lars
Re: [zest] Network with pre-defined coordinates [message #248238 is a reply to message #247620] Fri, 10 April 2009 02:25 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
Thanks Lars,
note, a user can likely still drag a node. Is this a problem for you?
cheers,
ian
Lars Vogel wrote:
> Best regards, Lars
Re: [zest] Network with pre-defined coordinates [message #249250 is a reply to message #248238] Thu, 11 June 2009 17:58 Go to previous message
Hi Ian,
Thank you for the answer. No dragging a node is actually I very nice
feature.
Best regards, Lars
Ian Bull wrote:
> Thanks Lars,
> cheers,
> ian
> Lars Vogel wrote:
>> Best regards, Lars
Previous Topic:Zoom in time too long
Next Topic:going from a create request directly to a direct edit
Current Time: Tue Jul 22 13:09:45 EDT 2025
Powered by FUDForum. Page generated in 0.06104 seconds
