Home » Language IDEs » Java Development Tools (JDT) » JDT: Code cleanup, final keyword, cannot disable
JDT: Code cleanup, final keyword, cannot disable [message #247543] Thu, 06 September 2007 17:15 Go to next message
In 3.3, just turned on cleanup and enabled the final keyword for local
vars. Well, later decided that it was not as cool as I thought and
unchecked the check box for final on local vars.
Even though checkbox is cleared, it keeps inserting final in front of
locals, and I cannot seem to get rid of it.
Anyone else seing this? I was going to open a bug but thought I should
start here first...
Re: JDT: Code cleanup, final keyword, cannot disable [message #247593 is a reply to message #247543] Thu, 06 September 2007 20:49 Go to previous messageGo to next message
> start here first...
This is a shot in the dark. Do you have project specific settings
enabled? If so make sure that it is turned off in the project.
Re: JDT: Code cleanup, final keyword, cannot disable [message #247598 is a reply to message #247543] Thu, 06 September 2007 21:47 Go to previous messageGo to next message
> start here first...
There are two different places where this is set, which I find a bit
confusing: Java -> Editor -> Save Actions -> Additional Actions and
Java -> Code Style -> Cleanup. Did you make sure it's off both places?
/Paul
Re: JDT: Code cleanup, final keyword, cannot disable [message #247724 is a reply to message #247598] Mon, 10 September 2007 11:45 Go to previous messageGo to next message
Ah, it was not 'project specific overrides', but the duplicate location
(cleanup & save action); one was checked, another was not.
I guess this should be considered a bug, no?
Re: JDT: Code cleanup, final keyword, cannot disable [message #247728 is a reply to message #247724] Tue, 11 September 2007 04:42 Go to previous message
Originally posted by: benno_baumgartner.ch.ibm.com
Hi David
Save actions are (as the name suggests) actions which are performed on
save whereas the clean up preferences configure how the Source > Clean
Up action works.
What are the steps to reproduce it?
Benno
Previous Topic:Cannot connect to VM error in Java debugger
Next Topic:How to avoid search hits in JAR files?
Current Time: Sat Sep 20 15:05:34 EDT 2025
Powered by FUDForum. Page generated in 0.04297 seconds
