Home » Eclipse Projects » Eclipse Platform » insert date/time stamp?
insert date/time stamp? [message #247517] Mon, 31 May 2004 08:02 Go to next message
Originally posted by: relaxedrob.remove.optusnet.com.au
Hi All!
Is it possible to insert a date-time stamp through the editor?
Thanks for any advice!
Rob
Re: insert date/time stamp? [message #247527 is a reply to message #247517] Mon, 31 May 2004 08:26 Go to previous messageGo to next message
Originally posted by: rndzank.comcast.net.not_this.net
If you didn't find any editor action that does it (I never looked for one,
assuming you tried) you can try code templates (Prefs/Java/Editor/Templates).
Create one for javadoc, named date with body containing ${date}, ${time}.
Then in JavaDoc you can type "da"+ Ctrl-SPACE and it will complete "date",
replace it with your template and evaluate the body.
r.
Robert Mark Bram wrote:
> Hi All!
> Rob
Re: insert date/time stamp? [message #247857 is a reply to message #247527] Tue, 01 June 2004 08:00 Go to previous messageGo to next message
Hi Richard,
Thank you very much for the response!
My goodness that was easy!
How can I find a list of these environment properties for other templates?
Rob
Re: insert date/time stamp? [message #248007 is a reply to message #247857] Tue, 01 June 2004 12:50 Go to previous message
In the same place. There is a button "insert var." that shows all
along with their descriptions.
Previous Topic:Debugging core classes
Next Topic:CVS perspective - how to set up "Repository location"
Current Time: Thu Jul 17 04:17:05 EDT 2025
Powered by FUDForum. Page generated in 0.08582 seconds
