Home » Eclipse Projects » GEF » [ZEST] Disable node replacing
[ZEST] Disable node replacing [message #247459] Sat, 21 February 2009 05:14 Go to next message
Originally posted by: simone.simonesaraceni.it
Hi, is it possible to disable user replacing nodes on Zest graph? How?
Re: [ZEST] Disable node replacing [message #248231 is a reply to message #247459] Fri, 10 April 2009 02:22 Go to previous messageGo to next message
Originally posted by: irbull.cs.uvic.ca
It might be possible by overriding the GraphNode class and replacing the
setLocation methods, but I'm not sure if all the necessary hooks are
visible. Can you try this, and file a bug, and I can investigate
opening the needed hooks.
cheers,
ian
Re: [ZEST] Disable node replacing [message #248301 is a reply to message #248231] Tue, 14 April 2009 04:02 Go to previous message
> cheers,
> ian
I've solved extending the Graph class and on constructor I've changed
the EventDispatcher:
//Disable node moving
getLightweightSystem().setEventDispatcher(new SWTEventDispatcher() {
public void dispatchMouseMoved(org.eclipse.swt.events.MouseEvent me) {
// If the current event is null, return
if (getCurrentEvent() == null) {
return;
if (getMouseTarget() == null) {
setMouseTarget(getRoot());
if ((me.stateMask & SWT.BUTTON_MASK) != 0) {
getMouseTarget().handleMouseDragged( getCurrentEvent());
} else {
getMouseTarget().handleMouseMoved( getCurrentEvent());
I take this code from the source code of Graph and remove the call to
dispachMouseMoved(MouseEvent) method.
I use this solution because is the simpliest that I've found.
Simone.
Previous Topic:Enabling Save function through performRequest
Next Topic:CreationTool.updateTargetRequest explanation
Current Time: Sat Jul 12 16:05:06 EDT 2025
Powered by FUDForum. Page generated in 1.04633 seconds
