Home » Newcomers » Newcomers » No Virtual Machine found
No Virtual Machine found [message #247458] Fri, 01 February 2008 16:33 Go to next message
Originally posted by: rodo2024.googlemail.com
Hello, I am a German student and i have the following problem.
I get following error mesasge when i click at eclipse.exe:
A JRE or JDK must be available to run eclipse. No javavisrtual machine was
found after searching the following locations
C:>Eclipse\eclipse\jre\bin\javaw.exe
i dont really understand why, because first i have JRE and JDK installed
and second i dont have them in the same folder as eclipse. i read that i
could call eclipse form the dosbox but i didnt really understandt how.
can someone tell me how do i make run eclipse normally. Thanks
Re: No Virtual Machine found [message #247463 is a reply to message #247458] Fri, 01 February 2008 16:47 Go to previous messageGo to next message
Rodo,
Eclipse will look for it in a few places and that's the last place it
will look failing the other tries. Most often it would find it on your
path. If you run java.exe, I'll be that's not found either because it's
not on your path. You can also use a -vm argument to tell it where to
look.
http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
Rodo wrote:
> Hello, I am a German student and i have the following problem. I get
> was found after searching the following locations
> installed and second i dont have them in the same folder as eclipse.
> i read that i could call eclipse form the dosbox but i didnt really
> understandt how. can someone tell me how do i make run eclipse
> normally. Thanks
Re: No Virtual Machine found [message #247468 is a reply to message #247458] Sat, 02 February 2008 06:22 Go to previous messageGo to next message
Thanks for the information but how do I tell eclipse the rigth path
Re: No Virtual Machine found [message #247473 is a reply to message #247463] Sat, 02 February 2008 06:37 Go to previous messageGo to next message
Ok thanks you dont need to reply i didnt saw the link.
thanks for the help
Rodolfo
Re: No Virtual Machine found [message #247485 is a reply to message #247468] Sat, 02 February 2008 13:34 Go to previous message
http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F#Find_the _JRE
HTH
Darins
"Rodo" <rodo2024@googlemail.com> wrote in message
news:9696a4088a9d0b464968a29b6559d443$1@www.eclipse.org...
Previous Topic:Customizing perspectives is too tedious, time-consuming
Next Topic:How to find out what editor is opened?
Current Time: Fri Jul 25 20:32:10 EDT 2025
Powered by FUDForum. Page generated in 0.09460 seconds
