Home » Archived » BIRT » XML Emitter
XML Emitter [message #247406] Wed, 11 July 2007 11:22 Go to next message
is ther any way to get the .xml format of report output. Is ther available
ant emmiter plugin for this.Any way to do it programitacally with less
effort
......venkat
Re: XML Emitter [message #247425 is a reply to message #247406] Wed, 11 July 2007 11:39 Go to previous messageGo to next message
Venkat,
Could you please elaborate on what you would like? I don't quite understand
what you are asking for.
Scott Rosenbaum
> available ant emmiter plugin for this.Any way to do it programitacally
> with less effort
> .....venkat
Re: XML Emitter [message #247430 is a reply to message #247425] Wed, 11 July 2007 11:48 Go to previous messageGo to next message
As like html, pdf, ...... emitters for birt reports i need an emitter for
"xml" format .
Is it available , or any way to get the birt report output in .xml format
Venkat
Re: XML Emitter [message #247434 is a reply to message #247430] Wed, 11 July 2007 12:46 Go to previous messageGo to next message
Originally posted by: mdavis.pashllc.com
The Excel Emitter outputs the Excel in XML format. You can change the
extension fro XLS to XML and view the results in a XML editor.
Venkat wrote:
> for "xml" format .
> Venkat
Re: XML Emitter [message #247466 is a reply to message #247430] Wed, 11 July 2007 17:16 Go to previous messageGo to next message
Venkat,
We have created custom XML emitters for clients. It really depends what
type of information you want in the XML output, e.g. what schema do you want
the report to output to.
Scott
> for "xml" format .
> format
> Venkat
Re: XML Emitter [message #247513 is a reply to message #247466] Thu, 12 July 2007 00:22 Go to previous messageGo to next message
Hi Scoot,
Can i have the emitters which were there (the cutomized which you
developed for u'r clients)
Thansk & Regards
Venkat
Re: XML Emitter [message #247847 is a reply to message #247513] Fri, 13 July 2007 13:04 Go to previous message
Venkat,
Sorry Venkat, the code belongs to the client and it is propietary. I would
happy to work with you on creating a solution that is appropriate for your
needs.
Scott
> Hi Scoot,
> Thansk & Regards
> Venkat
Previous Topic:Postgres 7.4 connections not closing
Next Topic:Locale set via report parameter
Current Time: Sat Jul 26 03:05:52 EDT 2025
Powered by FUDForum. Page generated in 0.07899 seconds
