Using the Ruby fast debugger with an home-installed ruby-debug gem [message #24314] |
Mon, 26 May 2008 11:24  |
Originally posted by: gioele.svario.it
is there a way to use the Ruby fast debugger in DLTK when the
ruby-debug{,-base,-ide} gems are installed in a non-system-wide fashion?
In my case gems are installed at ~/Applications/ruby/gems and they work
flawlessly in common scripts because I have both RUBYLIB and GEM_HOME set
to the correct directories. Somehow, when the debugger is launched by
DLTK these variables are not read/used.
Gioele <gioele@svario.it>
Re: Using the Ruby fast debugger with an home-installed ruby-debug gem [message #26680 is a reply to message #24518] |
Wed, 25 June 2008 04:14  |
Originally posted by: weirp03.gmail.com
Cou you do me a favour to send the documents about DLTK ?
Our team is planning to use the DLTK to develop a chemical language
IDE,but we are short of the documents about the DLTK ,including helping
document,developer guides,because there are little information about DLTK
in the Internet.
Thank you .
FUDForum. Page generated in 0.07327 seconds
