Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Using the Ruby fast debugger with an home-installed ruby-debug gem
Using the Ruby fast debugger with an home-installed ruby-debug gem [message #24314] Mon, 26 May 2008 11:24 Go to next message
Originally posted by: gioele.svario.it
is there a way to use the Ruby fast debugger in DLTK when the
ruby-debug{,-base,-ide} gems are installed in a non-system-wide fashion?
In my case gems are installed at ~/Applications/ruby/gems and they work
flawlessly in common scripts because I have both RUBYLIB and GEM_HOME set
to the correct directories. Somehow, when the debugger is launched by
DLTK these variables are not read/used.
Gioele <gioele@svario.it>
Re: Using the Ruby fast debugger with an home-installed ruby-debug gem [message #24356 is a reply to message #24314] Wed, 28 May 2008 09:12 Go to previous messageGo to next message
Hi Gioele,
Thanks for reporting this issue.
I have started looking on it - I think I will have exact details tomorrow.
Alex
Re: Using the Ruby fast debugger with an home-installed ruby-debug gem [message #24518 is a reply to message #24356] Thu, 29 May 2008 08:49 Go to previous messageGo to next message
I found 2 issues with ruby-debug at the moment:
1. the check if the ruby-debug gem is installed. Since it could be
installed in different places (and your situation is one of the
examples) we would provide option to disable this check for advanced users.
2. current version of ruby-debug is 0.10.1 and according to the
http://rubyforge.org/frs/shownotes.php?release_id=21031 it contains some
INCOMPATIBLE CHANGEs so we need to modify our code to handle that.
We will fix this issues in one of the next RCs.
regards,
Alex
Alex Panchenko wrote:
> Hi Gioele,
> Alex
Re: Using the Ruby fast debugger with an home-installed ruby-debug gem [message #26680 is a reply to message #24518] Wed, 25 June 2008 04:14 Go to previous message
Originally posted by: weirp03.gmail.com
Cou you do me a favour to send the documents about DLTK ?
Our team is planning to use the DLTK to develop a chemical language
IDE,but we are short of the documents about the DLTK ,including helping
document,developer guides,because there are little information about DLTK
in the Internet.
Thank you .
Previous Topic:Semantic checking - via validators?
Next Topic:Regarding DLTK IDE Guide
Current Time: Sun May 11 09:47:43 EDT 2025
Powered by FUDForum. Page generated in 0.04118 seconds
