Downloading eclipse-SDK-3.2-win32.zip [message #247160] |
Tue, 29 January 2008 16:31  |
Originally posted by: a.sara43.yahoo.com
I need to download eclipse-SDK-3.2-win32.zip.. I'm searching about it but
I couldn't find a reliable website to download from it..
I have downloaded the file eclipse-SDK-3.2-win32.zip multiple times, from
multiple sources, but always I got problems in extracting the file..
(Some files are corrupted and missing) although i'm using real ZIP tool
(such as WinZip and 7-zip)
Could any one help to solve this issue?
Thank You..
-Sara Angelo
Italy
Re: Downloading eclipse-SDK-3.2-win32.zip [message #247169 is a reply to message #247160] |
Tue, 29 January 2008 16:42   |
Originally posted by: wharley.bea.com
"Sara Angelo" <a.sara43@yahoo.com> wrote in message
news:06a1169cda44f69ce1ecab0aab66bc81$1@www.eclipse.org...
>I need to download eclipse-SDK-3.2-win32.zip.. I'm searching about it but I
>couldn't find a reliable website to download from it.. I have downloaded
>the file eclipse-SDK-3.2-win32.zip multiple times, from multiple sources,
>but always I got problems in extracting the file.. (Some files are
>corrupted and missing) although i'm using real ZIP tool (such as WinZip and
>7-zip)
First, I wonder why you're downloading Eclipse 3.2 given that there are many
newer versions available. Even if you need 3.2 for reasons such as the
existence of localized language packs, you should be considering Eclipse
3.2.2, rather than 3.2, because it contains many bug fixes.
But regardless of the version question, archived versions are available on
eclipse.org at http://archive.eclipse.org/eclipse/downloads/index.php . (To
get there from the Eclipse home page, follow the "Downloads" link, then "All
versions" under Eclipse Classic, and then the "archived builds" link.) That
server is highly reliable, so if you've been having problems downloading
from there, I suspect the problem is at your end, not the server.
Re: Downloading eclipse-SDK-3.2-win32.zip [message #247295 is a reply to message #247245] |
Thu, 31 January 2008 03:17  |
Originally posted by: al_PUBLIC.gmx.de
On Wed, 30 Jan 2008 08:00:09 -0800, "Walter Harley" <wharley@bea.com>
wrote:
>"Achim Lörke" <al_PUBLIC@gmx.de> wrote in message
>news:qcp0q3pst3tvmafldjfa58f786j994c1b7@4ax.com...
>> Since you already know that you have to use an external unzip program,
>> have you also used a root directory (such as c:\) to extract the
>> distribution into? In my experience this is the only reliable way to
>> extract Eclipse on Windows (tried on 2003 server, XP Pro and Vista
>> x64) systems.
>> You may of course move the resulting directory anywhere you like.
>It is indeed helpful to unpack to a directory with a fairly short name, to
>avoid path-length issues. However, it does not have to be a root directory.
>For instance, I generally unpack Eclipse to directories with names like
>"c:\eclipse34-i20080125" without any difficulty, using Winzip on Windows XP
>SP2.
OK, I just checked: my license for WinZip is fairly old (about 4
years), so maybe a current version does work better. I was trying to
give a hint as a last resort if everything else fails.
Achim
FUDForum. Page generated in 0.09166 seconds
