Home » Newcomers » Newcomers » project fail to create
project fail to create [message #246997] Mon, 28 January 2008 12:06 Go to next message
Originally posted by: wong_powah.yahoo.ca
I used eclipse 3.3.1.1 on windows 2000.
Sometimes when I tried to create a project, the project cannot be created.
How to find out the reason?
However, something with the same name as the project was created in the
workspace directory. Do I just delete that?
Otherwise, how to clean up the workspace directory?
Re: project fail to create [message #247013 is a reply to message #246997] Mon, 28 January 2008 14:15 Go to previous messageGo to next message
The project fail to create because of
java.lang.ExceptionInInitializerError.
I am trying to use debugger_tutorial_archive.zip from
http://eclipsetutorial.sourceforge.net/debugger.html
Re: project fail to create [message #247041 is a reply to message #247013] Mon, 28 January 2008 23:30 Go to previous messageGo to next message
Hi Powah. What version of Java do you have installed? Mark
Re: project fail to create [message #247083 is a reply to message #247041] Tue, 29 January 2008 09:45 Go to previous messageGo to next message
Originally posted by: powah.wong.gmail.com
JDK 1.5.0-14 on windows 2000.
Re: project fail to create [message #247117 is a reply to message #247083] Tue, 29 January 2008 12:37 Go to previous message
Hi Powah. A simple thing to try would be to just delete the entire
workspace directory and then start Eclipse. It will ask you for the
directory and allow you to create the workspace at that time. That way
you will know you are starting with a clean directory.
If you have something in the workspace you want to keep, then just
create a second directory that is empty and try it there. HTH. Mark
Previous Topic:Embedding Swing Code in Eclipse containers
Next Topic:Chart library for Eclipse
Current Time: Tue Jul 22 01:37:35 EDT 2025
Powered by FUDForum. Page generated in 0.10027 seconds
