Home » Language IDEs » Java Development Tools (JDT) » access restriction on JVM 1.5 org.w3c jars
access restriction on JVM 1.5 org.w3c jars [message #246829] Tue, 14 August 2007 14:27 Go to next message
Originally posted by: alexandre.magillem.com
Hi all, I've already posted this question in the platform newsgroup but
this seems a better place for it.
Since I have switched to Eclipse Europa, the org.w3c.dom.traversal jar
is not accessible anymore. To access it, I must explicitly change the
Error/Warnings preference (Forbidden Reference) from Error to Warning
(or Ignore).
Am I really accessing a restricted API ? As far as I understand, the
APIs in the org.w3c.dom.traversal package are public APIs.
Isn't there a problem in Eclipse 3.3 with the access rules definition
off this jar ? I don't know where these access rules are defined, but
with Eclipse 3.2, there are no such access rules defined on the JVM.
Thanks for your answers.
Regards.
Christophe
Re: access restriction on JVM 1.5 org.w3c jars [message #246845 is a reply to message #246829] Wed, 15 August 2007 10:35 Go to previous messageGo to next message
Access rules were added to "execution environments" in Europa (3.3) based on
standard specifications that describe what packages will be available at
runtime. Looking at the access rules, it appears that the J2SE-1.3
environment does not provide access to org.w3c.dom, but J2SE-1.4 does. What
execution environment is on your build path? Perhaps you need to upgraded to
1.4?
You can see the access rules on the environment on the project's "Java Build
Path" properties page. Look at the libraries tab, and expand the jars inside
the JRE System Library. The rules appear on each jar.
Darin Wright
"Christophe Alexandre" <alexandre@magillem.com> wrote in message
news:f9ss66$bq4$1@build.eclipse.org...
> Since I have switched to Eclipse Europa, the org.w3c.dom.traversal jar is
> Error/Warnings preference (Forbidden Reference) from Error to Warning (or
> Ignore).
> Am I really accessing a restricted API ? As far as I understand, the APIs
> Isn't there a problem in Eclipse 3.3 with the access rules definition off
> this jar ? I don't know where these access rules are defined, but with
> Regards.
> Christophe
Re: access restriction on JVM 1.5 org.w3c jars [message #246850 is a reply to message #246845] Wed, 15 August 2007 11:50 Go to previous messageGo to next message
I'm using J2SE-1.5 on OS X (10.4.10).
For the org.w3c.dom jars, the access rules are:
Accessible: org/w3c/dom/*
Accessible: org/w3c/dom/bootstrap/*
Accessible: org/w3c/dom/events/*
Accessible: org/w3c/dom/ls/*
but not:
org/w3c/dom/traversal/*
Regards.
Christophe
> 1.4?
> Darin Wright
>> Ignore).
>> Regards.
>> Christophe
Re: access restriction on JVM 1.5 org.w3c jars [message #247143 is a reply to message #246850] Fri, 31 August 2007 05:32 Go to previous messageGo to next message
Hi all,
I'm renewing this question-problem to ask if I should open a bug track
on this issue ?
Regards.
Christophe
> but not:
> Regards.
> Christophe
>> based on standard specifications that describe what packages will be
>> available at runtime. Looking at the access rules, it appears that the
>> J2SE-1.3 environment does not provide access to org.w3c.dom, but
>> J2SE-1.4 does. What execution environment is on your build path?
>> Perhaps you need to upgraded to 1.4?
>> Build Path" properties page. Look at the libraries tab, and expand the
>> jars inside the JRE System Library. The rules appear on each jar.
>> Darin Wright
>>> but this seems a better place for it.
>>> jar is not accessible anymore. To access it, I must explicitly change
>>> the Error/Warnings preference (Forbidden Reference) from Error to
>>> Warning (or Ignore).
>>> Regards.
>>> Christophe
Re: access restriction on JVM 1.5 org.w3c jars [message #247452 is a reply to message #247143] Wed, 05 September 2007 11:20 Go to previous message
Yes - and I see you have opened a bug. Thanks,
Darin
news:fb8n84$6ee$1@build.eclipse.org...
> Hi all,
> I'm renewing this question-problem to ask if I should open a bug track on
> this issue ?
> Regards.
> Christophe
Previous Topic:content assist problem
Next Topic:tools.jar
Current Time: Fri Jul 18 05:27:43 EDT 2025
Powered by FUDForum. Page generated in 0.77214 seconds
