Home » Eclipse Projects » Nebula » Will SWTPlus widgets be put into the nebula project?
Will SWTPlus widgets be put into the nebula project? [message #2074] Wed, 17 May 2006 18:49 Go to next message
Originally posted by: rcp.zimtek.com
SWTPlus stuff is awesome and I look forward to it's contribution to the
eclipse nebula project.
Eric
Re: Will SWTPlus widgets be put into the nebula project? [message #2120 is a reply to message #2074] Thu, 18 May 2006 11:14 Go to previous messageGo to next message
Hi Eric,
Yes I will be adding the SWTPlus stuff. I am just getting started with
the contributions.
-Chris
> Eric
Re: Will SWTPlus widgets be put into the nebula project? [message #4447 is a reply to message #2120] Fri, 09 June 2006 13:04 Go to previous messageGo to next message
Will the public interfaces for the SWT Plus widgets be preserved when the
widgets move to the nebula project?
thanks
spencer
"Chris Gross" <schtoo@schtoo.com> wrote in message
news:e4i300$5mk$2@utils.eclipse.org...
> Hi Eric,
> the contributions.
> -Chris
>> Eric
Re: Will SWTPlus widgets be put into the nebula project? [message #4585 is a reply to message #4447] Fri, 09 June 2006 15:06 Go to previous messageGo to next message
Probably not.
-Chris
> thanks
> spencer
>> Hi Eric,
>> the contributions.
>> Regards,
>> -Chris
>>> Eric
Re: Will SWTPlus widgets be put into the nebula project? [message #561532 is a reply to message #2074] Thu, 18 May 2006 11:14 Go to previous messageGo to next message
Hi Eric,
the contributions.
-Chris
> Eric
Re: Will SWTPlus widgets be put into the nebula project? [message #562106 is a reply to message #2120] Fri, 09 June 2006 13:04 Go to previous messageGo to next message
thanks
spencer
> Hi Eric,
> the contributions.
> -Chris
>> Eric
Re: Will SWTPlus widgets be put into the nebula project? [message #562152 is a reply to message #4447] Fri, 09 June 2006 15:06 Go to previous messageGo to next message
Probably not.
-Chris
> thanks
> spencer
>> Hi Eric,
>> the contributions.
>> Regards,
>> -Chris
>>> Eric
Re: In AGR While Creating Datapool, "Link to Datapool" is not visible [message #1788258] Wed, 30 May 2018 12:29 Go to previous message
Previous Topic:Welcome to eclipse.technology.nebula
Next Topic:RichTextEditor: Table-Tags are removed when set in editor?
Current Time: Thu May 08 07:47:31 EDT 2025
Powered by FUDForum. Page generated in 0.04925 seconds
