Home » Archived » DSDP - Mobile Tools for Java (MTJ) » Create a file in memory
Create a file in memory [message #24223] Sun, 21 December 2008 17:00 Go to next message
Originally posted by: news.s237965939.online.de
I want to create a file stream in memory. In my case it's a midifile.
This file has a specified format. The header and other blocks have
variables of different types. A byte[] buffer is associated to the
class. My question now is how can I easily write my different variables
sequentially into the buffer? How will the headerChunk.write() function
look like? Here comes a little excerpt.
TIA,
Hans
public class MidiFile extends ByteArrayInputStream {
class headerChunk {
final byte[] Id = { 'M', 'T', 'h', 'd' };
final int Size = 6;
short Format = 0;
short NumTracks = 1;
short TimeDiv;
void write(....); ????
Re: Create a file in memory [message #24266 is a reply to message #24223] Mon, 22 December 2008 08:06 Go to previous messageGo to next message
Hello Hans,
There are two classes that will help you, DataInputStream and
DataOutputStream. These classes let an application read primitive Java
data types from an underlying input stream in a machine-independent way.
Hope it helps you!
David Marques
Re: Create a file in memory [message #24307 is a reply to message #24266] Tue, 23 December 2008 06:35 Go to previous messageGo to next message
Hi David,
it's you again to give me tips. I've got it runnning now, not quite in a
manner which I hoped, but it works reliably.
Thanks and Merry Christmas,
Hans
David Marques wrote:
> Hello Hans,
> Hope it helps you!
> David Marques
Re: Create a file in memory [message #24348 is a reply to message #24307] Tue, 23 December 2008 07:26 Go to previous message
Hi Hans,
It is always a pleasure to help MTJ users.
Merry Christmas for you too,
David Marques
Re: Create a file in memory [message #569312 is a reply to message #24223] Mon, 22 December 2008 08:06 Go to previous message
Hello Hans,
Hope it helps you!
David Marques
Re: Create a file in memory [message #569348 is a reply to message #24266] Tue, 23 December 2008 06:35 Go to previous message
Hi David,
Hans
> Hello Hans,
> Hope it helps you!
> David Marques
Re: Create a file in memory [message #569366 is a reply to message #24307] Tue, 23 December 2008 07:26 Go to previous message
Hi Hans,
David Marques
Previous Topic:Create a file in memory
Next Topic:MTJ 0.9.1 Available
Current Time: Mon Sep 01 00:58:30 EDT 2025
Powered by FUDForum. Page generated in 0.26421 seconds
