Home » Modeling » GMF (Graphical Modeling Framework) » EMF attribute cannot be set
EMF attribute cannot be set [message #24215] Sun, 20 August 2006 11:11 Go to next message
Originally posted by: George.Z.Lei.gmail.com
Hi all,
When I set the attribute value of the EMF model from my edit parts, an
exception was always catched internally. The exception is as following
java.lang.IllegalStateException: Cannot modify resource set without a write
transaction
It happened when the model finished setting value for attribute and was
firing a notification. During the process, a transaction object was
retrieved and validated, and the transaction is readonly, therefore the
exception was thrown.
Who can help me to analyze the cause for the exception?
George
Re: EMF attribute cannot be set [message #25057 is a reply to message #24215] Mon, 21 August 2006 16:42 Go to previous messageGo to next message
George Lei wrote:
> Hi all,
> transaction
> George
You have to open a write transaction before doing any model changes
You will need to check who was trying to change the attribute without
having a write transaction
Re: EMF attribute cannot be set [message #30978 is a reply to message #25057] Sat, 26 August 2006 12:33 Go to previous message
"Mohammed Mostafa" <mmostafa@ca.ibm.com> wrote in message
news:ecd5sj$lsn$1@utils.eclipse.org...
> George Lei wrote:
> > Hi all,
write
> > transaction
> > Thanks,
> > George
In fact I am trying to set some model attribute in the constructor of edit
part. Maybe it is not a good idea.
Is there any better solution to set the attributes when the edit part is
created?
George
Previous Topic:Diagrams on Paper to Ecore
Next Topic:open a new diagram using OpenDiagramPolicy
Current Time: Fri Oct 24 15:52:57 EDT 2025
Powered by FUDForum. Page generated in 0.26009 seconds
