Home » Archived » Memory Analyzer (MAT) » No application id has been found.
No application id has been found. [message #2071] Wed, 28 May 2008 04:23 Go to next message
Originally posted by: wakim5000e.yahoo.de
The Version: 0.7.0.20080517 | Date: 17 May 2008 | Type: Nightly Build for
Win32 is not working. The following message appears in the log file:
SESSION 2008-05-28 10:04:54.907
eclipse.buildId=unknown
java.version=1.4.2_15
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.osgi 4 0 2008-05-28 10:04:55.735
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:234)
org.eclipse.equinox.internal.app.EclipseAppContainer.start(E clipseAppContainer.java:96)
org.eclipse.equinox.internal.app.Activator.addingService(Act ivator.java:127)
org.osgi.util.tracker.ServiceTracker$Tracked.trackAdding(Ser viceTracker.java:1064)
org.osgi.util.tracker.ServiceTracker$Tracked.trackInitialSer vices(ServiceTracker.java:926)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:330)
at org.osgi.util.tracker.ServiceTracker.open(ServiceTracker.jav a:274)
at org.eclipse.equinox.internal.app.Activator.start(Activator.j ava:56)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:419)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:354)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:427)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:383)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:371)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org.eclipse.core.internal.runtime.PlatformActivator.startApp Container(PlatformActivator.java:47)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:32)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:355)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1073)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:632)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:506)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:280)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:466)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:209)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:319)
Re: No application id has been found. [message #2087 is a reply to message #2071] Wed, 28 May 2008 07:42 Go to previous messageGo to next message
Hi Wakim,
the Memory Analyzer needs JDK5
Kind regards,
- Andreas.
Re: No application id has been found. [message #2101 is a reply to message #2087] Wed, 28 May 2008 07:51 Go to previous message
Run it with
MemoryAnalyzer.exe -vm <path to 1.5er vm>
Previous Topic:Static fields and heap usage
Next Topic:Webinar a/b Memory Analyzer
Current Time: Fri Jul 18 05:22:27 EDT 2025
Powered by FUDForum. Page generated in 0.07575 seconds
