Home » Eclipse Projects » GEF » scrollbar disappears when zooming
scrollbar disappears when zooming [message #245732] Wed, 08 October 2008 17:20 Go to next message
Whenever I use ZoomManager to zoom in or out, my scrollbar vanishes.
What am I missing that would cause this to happen? I am using
ScrollingGraphicalViewer.
Re: scrollbar disappears when zooming [message #245746 is a reply to message #245732] Thu, 09 October 2008 15:15 Go to previous messageGo to next message
Hi Mark,
You mean the scrollbar disappears when it is still needed?
The scrollbars currently disappear when the canvas shrinks smaller than the
viewport (there is nothing to scroll anymore).
Cheers...
Anthony
"Mark" <mproe@cerner.com> wrote in message
news:35abde542d706e329efdcd54ae9cd76d$1@www.eclipse.org...
> Hello,
> Thanks
Re: scrollbar disappears when zooming [message #245760 is a reply to message #245746] Fri, 10 October 2008 09:05 Go to previous messageGo to next message
Yes, the vertical scrollbar is disappearing when it is still needed. It
will always become visible again when I zoom back to 100%. But as soon as
I zoom in, it is gone. The mousewheel also becomes disabled, so I can't
scroll down period.
I should probably have mentioned I am using ScalableRootEditPart.
Mark
Anthony Hunter wrote:
> Hi Mark,
> Cheers...
> Anthony
>> Hello,
>> Thanks
Re: scrollbar disappears when zooming [message #245765 is a reply to message #245760] Mon, 13 October 2008 17:27 Go to previous messageGo to next message
Which OS platform ? Can you duplicate with the GEF Logic Example on your
Eclipse and OS platform ?
Cheers...
Anthony
news:2ed28c9db63971bd9f85d0a925096643$1@www.eclipse.org...
> scroll down period.
> Mark
>> Hi Mark,
>> the viewport (there is nothing to scroll anymore).
>> Cheers...
>> Anthony
>>> Hello,
>>> Thanks
Re: scrollbar disappears when zooming [message #245787 is a reply to message #245765] Tue, 14 October 2008 11:01 Go to previous messageGo to next message
I am on Vista. I tried the GEF Logic Example, and the scrolling works
fine when zoomed.
The only significant coding difference I noticed is the example uses
ScalableFreeformRootEditPart, and my application uses
ScalableRootEditPart. I am also using a multipage FormEditor instead of a
single EditorPart, but I wouldn't think that would affect anything.
There must be something simple I am missing here???
Mark
> Cheers...
> Anthony
>> scroll down period.
>> Thanks,
>> Mark
>>> Hi Mark,
>>> Cheers...
>>> Anthony
>>>> Hello,
>>>> Thanks
Re: scrollbar disappears when zooming [message #245796 is a reply to message #245787] Tue, 14 October 2008 17:21 Go to previous messageGo to next message
Hi Mark,
I am on Windows XP and when I swap out ScalableFreeformRootEditPart with
ScalableRootEditPart in the GEF Logic Example, I do not see any issues. Zoom
and scrollbars are fine.
It could be that the outer composite on the multipage FormEditor also is
trying to scroll and is breaking your GEF editor. You would have to try in a
regular editor to see.
Cheers...
Anthony
news:ba29649ba2ffab96a39a8706d98898dc$1@www.eclipse.org...
>I am on Vista. I tried the GEF Logic Example, and the scrolling works fine
>when zoomed.
> Mark
>> Cheers...
>> Anthony
>>> as I zoom in, it is gone. The mousewheel also becomes disabled, so I
>>> can't scroll down period.
>>> Thanks,
>>> Mark
>>>> Hi Mark,
>>>> Cheers...
>>>> Anthony
>>>>> Hello,
>>>>> Thanks
Re: scrollbar disappears when zooming [message #245827 is a reply to message #245796] Wed, 15 October 2008 12:04 Go to previous messageGo to next message
Okay, I narrowed down where the problem is occuring. But I don't know how
to get around it.
In my root edit part, I am creating a GridLayout to stack all my child
figures into a single column. For some strange reason, having a
GridLayout like this seems to screw up the scrolling calculations when
zoomed.
protected IFigure createFigure() {
Layer figure = new Layer();
GridLayout layout = new GridLayout(1, true);
layout.marginWidth = 15;
layout.marginHeight = 7;
layout.verticalSpacing = 5;
figure.setLayoutManager(layout);
return figure;
If I get rid of GridLayout and just display a single figure by itself, the
scrolling works fine.
return new TestFigure();
Any ideas?
Mark
> Hi Mark,
> Cheers...
> Anthony
>>when zoomed.
>> Thanks,
>> Mark
>>> Cheers...
>>> Anthony
>>>> Thanks,
>>>> Mark
>>>>> Hi Mark,
>>>>> Cheers...
>>>>> Anthony
>>>>>> Hello,
>>>>>> Thanks
Re: scrollbar disappears when zooming [message #245833 is a reply to message #245827] Wed, 15 October 2008 17:04 Go to previous messageGo to next message
Hi Mark,
No ideas, but you can raise a bug report for this in Bugzilla now that you
have a test case.
Cheers...
Anthony
news:8090006ba23cf1d765a42495936ca112$1@www.eclipse.org...
> to get around it.
> zoomed.
> @Override
> protected IFigure createFigure() { Layer figure = new Layer();
> return figure;
> @Override
> protected IFigure createFigure() { return new TestFigure();
> Any ideas?
> Mark
>> Hi Mark,
>> Zoom and scrollbars are fine.
>> in a regular editor to see.
>> Cheers...
>> Anthony
>>>fine when zoomed.
>>> a single EditorPart, but I wouldn't think that would affect anything.
>>> Thanks,
>>> Mark
>>>> your Eclipse and OS platform ?
>>>> Cheers...
>>>> Anthony
>>>>> It will always become visible again when I zoom back to 100%. But as
>>>>> soon as I zoom in, it is gone. The mousewheel also becomes disabled,
>>>>> so I can't scroll down period.
>>>>> Thanks,
>>>>> Mark
>>>>>> Hi Mark,
>>>>>> than the viewport (there is nothing to scroll anymore).
>>>>>> Cheers...
>>>>>> Anthony
>>>>>>> Hello,
>>>>>>> Thanks
Re: scrollbar disappears when zooming [message #245847 is a reply to message #245833] Thu, 16 October 2008 11:14 Go to previous messageGo to next message
I appreciate all your help, Anthony!
I have logged Bug #251093.
Mark
> Hi Mark,
> have a test case.
> Cheers...
> Anthony
>> to get around it.
>> zoomed.
>> @Override
>> return figure;
>> @Override
>> Any ideas?
>> Thanks,
>> Mark
>>> Hi Mark,
>>> Cheers...
>>> Anthony
>>>>fine when zoomed.
>>>> Thanks,
>>>> Mark
>>>>> Cheers...
>>>>> Anthony
>>>>>> Thanks,
>>>>>> Mark
>>>>>>> Hi Mark,
>>>>>>> Cheers...
>>>>>>> Anthony
>>>>>>>> Hello,
>>>>>>>> Thanks
Re: scrollbar disappears when zooming [message #245980 is a reply to message #245847] Wed, 29 October 2008 05:42 Go to previous messageGo to next message
please try
Figure figure = new FreeformLayer();
return figure;
Re: scrollbar disappears when zooming [message #515909 is a reply to message #245980] Mon, 22 February 2010 03:34 Go to previous messageGo to next message
any break thru in this???
Re: scrollbar disappears when zooming [message #523441 is a reply to message #515909] Fri, 26 March 2010 09:52 Go to previous message
sorry for revoking such an old issue...
This is a an old issue but still pending issue(another example of GEF is dead Twisted Evil )
upon analyses on certain zoom levels with a GridLayout on root figure...
The ScalableLayeredPane class asks for a prefered size in
 * @see Figure#getPreferredSize(int, int)
public Dimension getMinimumSize(int wHint, int hHint) {
	Dimension d = super.getMinimumSize((int) (wHint / getScale()), (int)(hHint / getScale()));
	int w = getInsets().getWidth();
	int h = getInsets().getHeight();
	return d.getExpanded(-w, -h)
		.scale(scale)
		.expand(w, h);
here width/hight hint is -1 in normal cases..
hence ((int) (wHint / getScale()) returns a zero(for higher then 1 scale) or some other negative value in lower scales
This leads to passing of width hint 0 in many cases.
ultimately in GridLayout.calculatePreferredSize method
     * (non-Javadoc)
     * @see org.eclipse.draw2d.AbstractLayout#calculatePreferredSize(org.eclipse.draw2d.IFigure,
     *      int, int)
    protected Dimension calculatePreferredSize(IFigure container, int wHint, int hHint)
        Dimension size = layout(container, false, 0, 0, wHint, hHint, /* flushCache */
        true);
        if (wHint != SWT.DEFAULT) size.width = wHint;
        if (hHint != SWT.DEFAULT) size.height = hHint;
         * Adjust for the size of the border
        size.expand(container.getInsets().getWidth(), container.getInsets().getHeight());
        size.union(getBorderPreferredSize(container));
        return size;
the zero width/height hint leads to 0 as prefered size.
The fix would be to check for SWT.DEFAULT width/height hint in ScalableLayeredPane class and accordingly pass on the SWT.DEFAULT value without applying scale changes.
Am i correct here,can any body varyfy the same so that this can be patched in the specified Bug #251093.
Previous Topic:GEF for iPad?
Next Topic:tracing source/code from model developed in gmf based editor
Current Time: Thu Jul 17 19:16:23 EDT 2025
Powered by FUDForum. Page generated in 0.27421 seconds
