Home » Language IDEs » Java Development Tools (JDT) » Developing custom refactorings - Is it possible only using Published API?
Developing custom refactorings - Is it possible only using Published API? [message #245697] Fri, 13 July 2007 07:29 Go to next message
I am looking at developing custom refactorings using the Eclipse's API and
I am trying to figure out if is it possible to do so solely through using
Eclipse's published API?
With regards developing custom refactorings I see Tobias Widmer in his
article "Unleashing the Power of Refactoring"
http://www.eclipse.org/articles/article.php?file=Article-Unl eashing-the-Power-of-Refactoring/index.html
uses internal classes (org.eclipse.jdt.internal.corext.dom.NodeFinder) in
order to develop his custom refactoring.
Is this not bad practice at a minimum (see Guidelines for using the
Eclipse API
http://www.eclipse.org/articles/article.php?file=Article-API -Use/index.html
) and unsafe with regards the plugin breaking when running against future
releases of Eclipse due to dependencies on internal API?
I want to develop some custom refactorings - is it just the case that in
order to develop custom refactorings I will more than likely need to use
some internal classes? And the best I can do is to request any internal
API I use to be put into the published API in the future and fix things
down the line, whilst in the meantime dealing with any breakage in the
code between Eclipse releases due to dependencies on internal API?
Any help\advice greatly appreciated,
Máirtín
p.s. I had this issue in another thread titled "Calling Refactorings
Programmatically", but this I think is a seperate issue so I have broken
it of into its own thread.
Re: Developing custom refactorings - Is it possible only using Published API? [message #245768 is a reply to message #245697] Fri, 13 July 2007 10:53 Go to previous messageGo to next message
Originally posted by: jacek.pospychala.pl.ibm.com
Máirtín,
you can write similar class to NodeFinder by extending ASTVisitor. It's
internal, because it's helper class for JDT needs, so if JDT needs
change, this class may also change. Personally, I think it should not be
used in the article, but I guess, author wanted to keep the example
simple and minimize the number of classes. Anyway, I'd suggest raising a
bug against this article (Foundation/Articles component), and writing
similar class for your own in your plug-in.
Generally speaking, the minimal API required to write custom
refactorings is available as it's outlined in article. But the deeper
you get into writing refactorings, the more stuff you may need to
process all the relationships and constraints. JDT team has made quite a
lot refactorings possible over years, thus they have a nice library of
useful classes (like NodeFiner), but I doubt if any of these would
become API, because then they'd also become hard to modify, as API has
to be kept backward compatible.
> and I am trying to figure out if is it possible to do so solely
> through using Eclipse's published API?
> in order to develop his custom refactoring.
> Eclipse API
> future releases of Eclipse due to dependencies on internal API?
> in order to develop custom refactorings I will more than likely need
> to use some internal classes? And the best I can do is to request any
> internal API I use to be put into the published API in the future and
> fix things down the line, whilst in the meantime dealing with any
> breakage in the code between Eclipse releases due to dependencies on
> internal API?
> Máirtín
> broken it of into its own thread.
Re: Developing custom refactorings - Is it possible only using Published API? [message #245773 is a reply to message #245768] Fri, 13 July 2007 13:11 Go to previous message
Thanks for the reply.
So would it be correct to say that there are two "categories" of internal
classes
(1) Helper classes
(2) Non-helper classes
And should one require the use of these classes they should do the
following
(1) Helper classes - replicate the class (or write something similiar)
(2) Non-helper classes - use directly and request that they be put into
the published API?
-- máirtín
Previous Topic:APT for CDT
Next Topic:Heads up: Eclipse on MacOS
Current Time: Thu Jul 17 19:32:08 EDT 2025
Powered by FUDForum. Page generated in 0.03447 seconds
