InputStream's for oda XML datasource [message #245670] |
Sat, 30 June 2007 04:24  |
Originally posted by: blaxter.gmail.com
Hi, I'm using BIRT in my own application, i've reports that need
several xml as datasource (let's say 'n', n > 1), i'd like birt process
them as an InputStream, so the answer would be
set "org.eclipse.birt.report.data.oda.xml.inputStream" but i have a lot of
InputStream not only one. I don't know how could be the best way for doing
that, subreports, script datasource, another oda driver that extends odaxml...
Re: InputStream's for oda XML datasource [message #245951 is a reply to message #245670] |
Mon, 02 July 2007 10:55  |
You could setup a separate data set for each or use the new web service
data source that allows calling a custom class where you combine all of
the InputStreams in code.
Jason
FUDForum. Page generated in 0.03003 seconds
