Home » Archived » BPMN Modeler » Adding a new property for sequence edges
Adding a new property for sequence edges [message #2064] Mon, 20 October 2008 02:16 Go to next message
hi :)
I'd like to add a new property (in the property view) for sequence edges
in the BPMN-program.
Unfortunately just editing the ecore-metamodel bpmn.ecore, extracting it
into bpmn.ecore_diagram
and running the whole code as an eclipse application doesn't work.
Has anyone an idea oder can tell me how to do that?
Many thanks in advance!
Sven
Re: Adding a new property for sequence edges [message #2078 is a reply to message #2064] Mon, 20 October 2008 05:10 Go to previous messageGo to next message
Originally posted by: atoulme.intalio.com
Hi Sven,
you shoud follow the tutorial we had developed for EclipseCon 2007, that
has been kept as a sample.
Here:
http://wiki.eclipse.org/STP/BPMN_Component/STP_BPMN_Presenta tion_Hands_on_tutorial
It does everything you want.
Antoine
Sven wrote:
> hi :)
> Sven
Re: Adding a new property for sequence edges [message #3126 is a reply to message #2078] Mon, 27 October 2008 14:04 Go to previous messageGo to next message
hi,
thank you very much for posting the link of the tutorial such quickly!
Unfortunately I couldn't find any method "createControls" or "setInput"
for SequenceEdges, so that I couldn't add a new String-Property for them.
( http://wiki.eclipse.org/STP/BPMN_Component/STP_BPMN_Presenta tion_Hands_on_tutorial#Adding_a_property_tab_to_create_your_ annotation)
It seems, that Sequence Edges and other original objects use a different
way of doing that.
I also tried to copy and rename everything that had to do with the
documentation-Property (which is also a String-property) and hoped that it
works, although it's not a special property for sequence edges, but
unfortunately it didn't work.
Can anyone tell me how to add a String-Property especially for
SequenceEdges
or wether I have overlooked the necessary methods? (I searched for the
methods in the whole workspace
http://dev.eclipse.org/svnroot/stp/org.eclipse.stp.bpmn/trun k)
Sven
Re: Adding a new property for sequence edges [message #3158 is a reply to message #3126] Tue, 28 October 2008 05:19 Go to previous messageGo to next message
Hi.
The createControls and setInput methods are methods of the
PropertySection, not SequenceEdge.
The setInput method is called whenever the selection in the editor
changes and you get the latest selection passed as the argument.
There u have to check if it is an IGraphicalEditPart and resolve the
semantic element. If this element is an instance of SequenceEdge u can
add a new (or edit the old) EAnnotation and put your new property in there.
Thats it.
Greets
Till
Sven schrieb:
> hi,
> way of doing that.
> it works, although it's not a special property for sequence edges, but
> SequenceEdges
> Sven
Re: Adding a new property for sequence edges [message #3225 is a reply to message #2064] Wed, 29 October 2008 16:30 Go to previous messageGo to next message
hi
first of all, thank you very much for you help!!
Finally it's much more simple than it seemed to be.
At first, you have to change the ecore-model
"../org.eclipse.stp.bpmn/model/bpmn.ecore" by adding a new EAttribute as a
child of Sequence Edges with the datatype String and a specific name (in
this case conditionExpression).
Moreover you have to right click on bpmn.genmodel, afterwards on "Reload"
and then select the ecoremodel in the following windows. Then click on
Finish.
At last you have to generate the new program code by double-clicking on
bpmn.genmodel, right-clicking on the root of the tree ("Bpmn") and click
on "Generate all". That's it :)
Sven
Re: Adding a new property for sequence edges [message #3257 is a reply to message #3225] Wed, 29 October 2008 18:53 Go to previous message
Sven, we discourage people to do that and we recommend they use
annotations as the model may change at any time.
Antoine
Sven wrote:
> hi
> a child of Sequence Edges with the datatype String and a specific name
> (in this case conditionExpression).
> "Reload" and then select the ecoremodel in the following windows. Then
> click on Finish.
> Sven
Previous Topic:BPMN Modeler Creation Review
Next Topic:BPMN copy with references
Current Time: Thu Jul 17 15:56:02 EDT 2025
Powered by FUDForum. Page generated in 0.12438 seconds
