Ajax Toolkit Framework (1.0.1) requires feature "org.eclipse.wst (1.5.0)", or eq [message #245640] |
Tue, 15 January 2008 13:51  |
Originally posted by: rrsahana.us.ibm.com
I am trying to install ATF (atf-windows-0.1-20060912-1400.zip) I get the
following error so I couldn't complete my installation.
or equivalent.
I have
Eclipse : wtp-all-in-one-sdk-R-2.0.1-20070926042742-win32.zip
Tomcat : apache-tomcat-5.5.25.exe
xul Runner : xulrunner-1.8.0.1.en-US.win32.zip
java : java version "1.5.0"
Java(TM) 2 Runtime Environment, Standard Edition (build
pwi32devifx-20070725 (SR
5a))
IBM J9 VM (build 2.3, J2RE 1.5.0 IBM J9 2.3 Windows XP x86-32
j9vmwi3223-2007042
6 (JIT enabled)
J9VM - 20070420_12448_lHdSMR
JIT - 20070419_1806_r8
GC - 200704_19)
JCL - 20070725
I also tried after unzip the file wtp-wst-S-3.0M4-20080105091323.zip into
eclipse directory but no luck.
don't know if I am missing anything. Any help would be appreciated. Thanks
Re: Ajax Toolkit Framework (1.0.1) requires feature "org.eclipse.wst (1.5.0)", or eq [message #245645 is a reply to message #245640] |
Tue, 15 January 2008 14:22  |
Hi Regunathan,
You have downloaded wtp-all-in-one-sdk-R-2.0.1-20070926042742-win32.zip
and after that installed wtp-wst-S-3.0M4-20080105091323.zip
which I think is the problem.
The version of wtp form 20070926042742 contains the feature
org.eclipse.wst_2.1.0.v200709160540
And as you said atf needs org.eclipse.wst (1.5.0).
Since the first version number of the feature is change from 1 to 2
there might be incompatible changes, and the features might not be
equivalent.
Not sure if this is the problem, but try downloading the specified
version of wst.
It would be a good place to ask this question in the WTP newsgroup.
Best Regards,
Kiril
Ragunathan wrote:
> Hello,
> (1.5.0)", or equivalent.
> I have
> 5a))
> j9vmwi3223-2007042
> 6 (JIT enabled)
> GC - 200704_19)
> JCL - 20070725
> into eclipse directory but no luck.
FUDForum. Page generated in 0.32441 seconds
