Home » Eclipse Projects » GEF » Create a Diamond Class using Polygon Class in GEF
Create a Diamond Class using Polygon Class in GEF [message #24136] Sat, 05 October 2002 14:04 Go to next message
Originally posted by: sy_cheung.yahoo.com
public class ConditionalFigure extends Polygon {
I create a Diamond Class by extending the Polygon class in GEF. And in
the constructor of the Diamond class, I add the 4 points of the Diamond
by calling the setPoints() method.
But when I draw this figure, eclipse workbrench will use up 100% of the
CPU. My question is if this is the right approach of creating a Diamond
class? I try create a Rectangle class and rotate it 90 degree, but there
is no rotate method in the Rectangle class.
Thank you for any help.
public class Diamond extends Polygon {
public Diamond {
PointList pList = new PointList(4);
pList.addPoint(8, 0);
pList.addPoint(0, 8);
pList.addPoint(8, 8);
pList.addPoint(16, 8);
setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #24360 is a reply to message #24136] Sun, 06 October 2002 16:08 Go to previous messageGo to next message
Is there an example of using Polygon/Polyline in GEF?
I try to create Diamond class by extending the Polygon class, in the
constructor of the Diamond, it add points for the Diamond,
but when it is being drawn, GEF runns in a infinite loop.
Here is what I did:
public Diamond {
setPoints(pList);
Thanks for any help.
> public Diamond {
> setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #24400 is a reply to message #24360] Sun, 06 October 2002 17:23 Go to previous messageGo to next message
Sam,
Look at PolygonDecoration for some inspiration, that is a fastest way to
create something similar. You may also take a look at attached example
(small image + some code) for a customised versions of Polyline/Polygone.
Rotations are rather primitive and if you need to rotate/move/scale complex
figures you will need to write your own version of Transform (at least I
have such feeling). Using current implementation keep in mind that your
center of rotation always have (0,0) coordinate and define you figures
accordingly.
as
"Sam" <sy_cheung@yahoo.com> wrote in message
news:3DA0983B.6030104@yahoo.com...
> Here is what I did:
> public Diamond {
> setPoints(pList);
> > Hi,
> > public Diamond {
> > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #24485 is a reply to message #24400] Sun, 06 October 2002 17:41 Go to previous messageGo to next message
Originally posted by: sy_cheung2.yahoo.com
Alex,
Thanks for your help.
I notice you have 2 class PolylineEx and PolygonEx.
What are the difference between these 2 classes and the Polyline and Polygon
in org.eclipse.draw2d.
Thanks. again.
"Alex Selkov" <as@empproject.com> wrote in message
news:anq8a8$ptt$1@rogue.oti.com...
> Sam,
complex
> accordingly.
> as
> > Hi,
> > Here is what I did:
> > public Diamond {
> > setPoints(pList);
> > > Hi,
Diamond
the
Diamond
there
> > > public Diamond {
> > > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #24525 is a reply to message #24485] Sun, 06 October 2002 18:49 Go to previous messageGo to next message
setBounds, setScale, setRotation
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:anq9aj$qbn$1@rogue.oti.com...
> Alex,
Polygon
> Thanks. again.
> > Sam,
Polyline/Polygone.
> complex
I
> > accordingly.
> > Regards,
> > as
> > > Hi,
> > > Here is what I did:
> > > public Diamond {
> > > setPoints(pList);
> > > > Hi,
in
> Diamond
> the
> Diamond
> there
> > > > public Diamond {
> > > > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #24725 is a reply to message #24525] Sun, 06 October 2002 21:12 Go to previous messageGo to next message
news:anqdbb$rkb$1@rogue.oti.com...
The original draw2d versions are different. The intended usage there is
that you set the POINTS, and the bounds of the figure are a side-effect of
setting the points.
I haven't looked at Alex's implementation yet, But I'm guessing that in his
implementation, you provide a PointList relative to 0,0, and that PointList
is stretched and translated until it fills the bounds of the figure. We'd
like to provide this in draw2d as well. Any suggestions on distinguishing
the two names?
> > Alex,
> Polygon
> > Thanks. again.
> > > Sam,
to
> Polyline/Polygone.
> > complex
least
> I
your
> > > accordingly.
> > > Regards,
> > > as
> > > > Hi,
> > > > Here is what I did:
> > > > public Diamond {
> > > > setPoints(pList);
> > > > > Hi,
And
> in
> > Diamond
of
> > the
> > Diamond
> > there
> > > > > public Diamond {
> > > > > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #24799 is a reply to message #24725] Mon, 07 October 2002 08:29 Go to previous messageGo to next message
You are right, I simply use your Decoration as a prototype. My Polyline is
compatible with draw2d version because I use inverse trasfomation in
addPoint/setPoint. All of my code looks ugly and cry for refactoring because
a lot of functionality can be pulled up. For example two identical versions
of Polygone distingushed only by the name of superclass. PolygonDecorations
and PolylineDecorations can be trivial classes. Currently it's difficult to
suggest a good name prior to refactoring... A small number of interfaces may
be also a useful addition (Rotatable, Scalable etc)
And notifications also looks complicated from a user perspective:
firePropertyChange in Polyline to support connections looks unnatural for
generic Polyline figure, fireMoved must be fired when I change
shape/orientation to support attached connections correctly... I think that
your future article about complex figures must touch this issue.
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:anqlo3$uav$1@rogue.oti.com...
> setting the points.
his
PointList
> the two names?
> > > Alex,
> > Polygon
> > > Thanks. again.
> > > > Sam,
way
> to
example
> > Polyline/Polygone.
> > > complex
> least
> > I
> your
figures
> > > > accordingly.
> > > > Regards,
> > > > as
> > > > > Hi,
the
> > > > > Here is what I did:
> > > > > public Diamond {
> > > > > setPoints(pList);
> > > > > > Hi,
> And
> > in
> > > Diamond
> of
> > > the
> > > Diamond
but
> > > there
> > > > > > public Diamond {
> > > > > > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #25243 is a reply to message #24725] Mon, 07 October 2002 19:47 Go to previous messageGo to next message
I am using the Polygon in the original draw2d version. And I define the
points of the Diamond in the constructor,
But when the diamond is being painted, i will run into an infinte loop.
Could you please tell me if there is any thing wrong with the following
code, if not, why I will run into an infinite loop when I paint this?
public Diamond extends Polygon {
public Diamond {
setPoints(pList);
> setting the points.
his
PointList
> the two names?
> > > Alex,
> > Polygon
> > > Thanks. again.
> > > > Sam,
way
> to
example
> > Polyline/Polygone.
> > > complex
> least
> > I
> your
figures
> > > > accordingly.
> > > > Regards,
> > > > as
> > > > > Hi,
the
> > > > > Here is what I did:
> > > > > public Diamond {
> > > > > setPoints(pList);
> > > > > > Hi,
> And
> > in
> > > Diamond
> of
> > > the
> > > Diamond
but
> > > there
> > > > > > public Diamond {
> > > > > > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #25324 is a reply to message #25243] Mon, 07 October 2002 21:13 Go to previous messageGo to next message
You'll have to post a complete testcase and/or stacktrace.
news:ant52m$b5c$1@rogue.oti.com...
> public Diamond {
> setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #25644 is a reply to message #25324] Tue, 08 October 2002 11:09 Go to previous messageGo to next message
During the infinite loop, I suspend the main loop, this is the first stack
trace:
Thread [main] (Suspended)
java.util.ArrayList.indexOf(java.lang.Object) line: 216 [local variables
unavailable]
java.util.ArrayList.contains(java.lang.Object) line: 197
org.eclipse.draw2d.DeferredUpdateManager.addInvalidFigure(or g.eclipse.draw2d
..IFigure) line: 59
org.eclipse.draw2d.FigureCanvas$InternalLightweightSystem$Pr oxyRootFigure(or
g.eclipse.draw2d.Figure).revalidate() line: 1011
org.eclipse.draw2d.FreeformViewport(org.eclipse.draw2d.Figur e).revalidate()
line: 1013
org.eclipse.draw2d.FreeformLayeredPane(org.eclipse.draw2d.Fi gure).revalidate
() line: 1013
org.eclipse.draw2d.FreeformLayer(org.eclipse.draw2d.Figure). revalidate()
line: 1013
line: 1013
org.eclipse.draw2d.FreeformLayer$1.figureMoved(org.eclipse.d raw2d.IFigure)
line: 22
org.projectd.test.figures.Diamond(org.eclipse.draw2d.Figure) .fireMoved()
line: 301
org.projectd.test.figures.Diamond(org.eclipse.draw2d.Figure) .setBounds(org.e
clipse.draw2d.geometry.Rectangle) line: 1056
org.eclipse.draw2d.FreeformLayout(org.eclipse.draw2d.XYLayou t).layout(org.ec
lipse.draw2d.IFigure) line: 97
org.eclipse.draw2d.FreeformLayer(org.eclipse.draw2d.Figure). layout() line:
778
org.eclipse.draw2d.FreeformLayer(org.eclipse.draw2d.Figure). validate()
line: 1320
line: 1322
org.eclipse.draw2d.FreeformLayeredPane(org.eclipse.draw2d.Fi gure).validate()
line: 1322
org.eclipse.draw2d.FreeformLayeredPane.validate() line: 42
org.eclipse.draw2d.FreeformViewport(org.eclipse.draw2d.Figur e).validate()
line: 1322
org.eclipse.draw2d.FreeformViewport(org.eclipse.draw2d.Viewp ort).validate()
line: 325
g.eclipse.draw2d.Figure).validate() line: 1322
org.eclipse.draw2d.FigureCanvas$InternalLightweightSystem$Pr oxyRootFigure.va
lidate() line: 332
org.eclipse.draw2d.DeferredUpdateManager.validateFigures() line: 161
org.eclipse.draw2d.DeferredUpdateManager.performUpdate() line: 90
org.eclipse.draw2d.DeferredUpdateManager$UpdateRequest.run() line: 37
org.eclipse.swt.widgets.RunnableLock.run() line: 31
org.eclipse.ui.internal.UISynchronizer(org.eclipse.swt.widge ts.Synchronizer)
..runAsyncMessages() line: 94
org.eclipse.swt.widgets.Display.runAsyncMessages() line: 1599
org.eclipse.swt.widgets.Display.readAndDispatch() line: 1372
org.eclipse.ui.internal.Workbench.runEventLoop() line: 1272
org.eclipse.ui.internal.Workbench.run(java.lang.Object) line: 1255
org.eclipse.core.internal.boot.InternalBootLoader.run(java.l ang.String,
java.net.URL, java.lang.String, java.lang.String[], java.lang.Runnable)
line: 775
org.eclipse.core.boot.BootLoader.run(java.lang.String, java.net.URL,
java.lang.String, java.lang.String[]) line: 432
EclipseRuntimeLauncher.main(java.lang.String[]) line: 24
and the I resume it, the cpu goes up to 100% again, and here is the second
stack trace:
org.eclipse.draw2d.FreeformHelper.updateFreeformBounds(org.e clipse.draw2d.ge
ometry.Rectangle) line: 26
org.eclipse.draw2d.FreeformLayer.updateFreeformBounds(org.ec lipse.draw2d.geo
metry.Rectangle) line: 44
ometry.Rectangle) line: 27
org.eclipse.draw2d.FreeformLayeredPane.updateFreeformBounds( org.eclipse.draw
2d.geometry.Rectangle) line: 36
org.eclipse.draw2d.FreeformViewport.readjustScrollBars() line: 31
line: 326
lidate() line: 332
line: 775
news:anta54$d7h$1@rogue.oti.com...
> > public Diamond {
> > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #25676 is a reply to message #25644] Tue, 08 October 2002 11:16 Go to previous messageGo to next message
news:anur3c$9bq$1@rogue.oti.com...
> trace:
> unavailable]
> .IFigure) line: 59
> line: 1013
> () line: 1013
> line: 1013
> line: 1013
> line: 22
> line: 301
line:
> 778
> line: 1320
> line: 1322
> line: 1322
> line: 1322
> line: 325
> lidate() line: 332
> line: 775
> stack trace:
> line: 326
> lidate() line: 332
> line: 775
the
loop.
following
> > > public Diamond {
> > > setPoints(pList);
Re: Create a Diamond Class using Polygon Class in GEF [message #25985 is a reply to message #25644] Wed, 09 October 2002 10:12 Go to previous message
Do you have the Scrollbars set to ALWAYS be visible? FreeformFigures can
cause a cycle in the layout if the scrollbars automatically pop in and out.
this might be causing the problem. This limitation was mention, albeit
poorly, in a previous post on the newsgroup.
> trace:
> unavailable]
> .IFigure) line: 59
> line: 1013
> () line: 1013
> line: 1013
> line: 1013
> line: 22
> line: 301
line:
> 778
> line: 1320
> line: 1322
> line: 1322
> line: 1322
> line: 325
> lidate() line: 332
> line: 775
> stack trace:
> line: 326
> lidate() line: 332
> line: 775
the
loop.
following
> > > public Diamond {
> > > setPoints(pList);
Previous Topic:Shouldn't getDragTracker() return always the same instance of a DragTracker?
Next Topic:draw2d: findMouseEventTarget
Current Time: Sat Aug 30 19:34:52 EDT 2025
Powered by FUDForum. Page generated in 0.06152 seconds
