Home » Language IDEs » AspectJ » Newbie Eclipse AJDT Install Question
Newbie Eclipse AJDT Install Question [message #24105] Thu, 26 June 2003 13:48 Go to next message
Originally posted by: bluecoder.elivefree.net
I have installed the aspectJ plugin for Eclipse 2.1. I have verified the
install and followed the post-install instructions. I have imported the
examlpe telelcom and included the external jar "aspectjdt.jar".
My steps were:
- created an aspectJ project named "test",
- and inside this I created a package called "telecom"
- inside "telecom", I imported all the files that came with aspectJ
- then I choose "ReBuild Project" from Project menu
- then I choose "Run..." from Run menu
- I filled in "test" for project
- and filled in "telecom.BillingSimulation" for Class and choose run
But I get the following error:
"Exception in thread main java.lang.NoClassDefFoundError:
telecom/BillingSimulation"
I would like to know what I am doing wrong ? as this works from the
command line. Thank-you
B.C.
Re: Newbie Eclipse AJDT Install Question [message #24110 is a reply to message #24105] Fri, 27 June 2003 11:03 Go to previous messageGo to next message
Hi Brian,
From your note it doesn't appear that you are doing anything wrong. The
steps all work for me in my Eclipse 2.1 environment using the latest AJDT.
A couple of points need clarification though :-
(a) When you created your new "test" AspectJ project in Eclipse you should
have automatically got the aspectjrt.jar (I assume you didn't mean
aspectjdt.jar) imported for you. It should reside at the location <your
eclipse dir>\plugins\org.aspectj.ajde_<ajdt version>. You should not have
had to do a manual import. Right click on your project in the package
explorer and select "Remove AspectJ Nature" then immediately right click on
it again and select "Convert to AspectJ Project" just to be certain.
(b) When you supplied the name of the main class did you type it in the
"Main class:" field or did you search for it using the "Search..." button
on the right of that field ? If you did a search for it you should have
been presented with three potential main classes (BasicSimulation,
BilingSimulation and TimimgSimulation). If you didn't see these then your
project building step may not have worked.
Good luck !
On Thu, 26 Jun 2003 17:48:17 +0000 (UTC), Brian. C.
<bluecoder@elivefree.net> wrote:
> My steps were: - created an aspectJ project named "test", - and inside
> B.C.
George
Re: Newbie Eclipse AJDT Install Question [message #24115 is a reply to message #24110] Fri, 27 June 2003 12:44 Go to previous messageGo to next message
Hi George,
Thank you for your reply. Yes the jar was automaticallty put into the
project directory but when I tried clicking on "billing.lst" and "select
this build config" it said it could not find the jar so I imported it
manually and the error went away.
I have done what you said "Remove AspectJ Nature" then "Convert to
AspectJ Project", but I still get the same error. In the main class in
"Run..." I do not get any return results but the build did not return an
error either and nothing in the .log file. What should I do to build it
correctly ? Thank you for your help so far
B.
George Harley wrote:
> Hi Brian,
> Good luck !
> > Hi,
> > B.C.
> George
Re: Newbie Eclipse AJDT Install Question [message #24122 is a reply to message #24115] Sun, 29 June 2003 17:29 Go to previous messageGo to next message
OK, this sounds bad. Could you let me know the following please :-
(a) the version of AJDT plugin (1.1.2 or 1.1.3 or ?)
(b) level of Java
(c) operating system
(d) What do you see in the AJDT event trace when you open your project, run
a build etc ? Do you see any errors or warnings ? The AJDT event trace can
be displayed by carrying out the following steps with your project open in
the Java Perspective ... Window ->Show View->Other...->expand AspectJ
folder->AJDT Event Trace.
For example, here is what I see in my trace when I do a successful build
using billing.lst :-
22:24:16 Configuration file C:\Eclipse-
21\eclipse\workspace\test\src\telecom\billing.lst selected for test
22:24:16 build: Kind=FULLBUILD
22:24:16 Building test with config C:\Eclipse-
21\eclipse\workspace\test\src\telecom\billing.lst.
CLASSPATH=C:\sun-jdk-141-02\jre\lib\rt.jar;C:\sun-jdk-141-
02\jre\lib\sunrsasign.jar;C:\sun-jdk-141-02\jre\lib\jsse.jar ;C:\sun-jdk-
141-02\jre\lib\jce.jar;C:\sun-jdk-141-02\jre\lib\charsets.ja r;C:\sun-jdk-
141-02\jre\lib\ext\dnsns.jar;C:\sun-jdk-141-
02\jre\lib\ext\ldapsec.jar;C:\sun-jdk-141-
02\jre\lib\ext\localedata.jar;C:\sun-jdk-141-
02\jre\lib\ext\sunjce_provider.jar;C:\Eclipse-
21\eclipse\workspace\test\bin;C:\Eclipse-
21\eclipse\plugins\org.aspectj.ajde_1.1.2\aspectjrt.jar;
22:24:17 build: Kind=AUTOBUILD
22:24:17 build: AUTOBUILD requested but AUTOBUILD suppressed in workbench
preferences
Bye for now,
George
On Fri, 27 Jun 2003 16:44:53 +0000 (UTC), B.C. <bluecoder@elivefree.net>
wrote:
> Hi George,
> B.
>> Hi Brian,
>> AJDT. A couple of points need clarification though :-
>> should have automatically got the aspectjrt.jar (I assume you didn't
>> mean aspectjdt.jar) imported for you. It should reside at the location
>> <your eclipse dir>\plugins\org.aspectj.ajde_<ajdt version>. You should
>> not have had to do a manual import. Right click on your project in the
>> package explorer and select "Remove AspectJ Nature" then immediately
>> right click on it again and select "Convert to AspectJ Project" just to
>> be certain.
>> button on the right of that field ? If you did a search for it you
>> should have been presented with three potential main classes
>> (BasicSimulation, BilingSimulation and TimimgSimulation). If you didn't
>> see these then your project building step may not have worked.
>> Good luck !
>> > Hi,
>> the
>> the
>> > B.C.
>> -- George
George
AJDT Development
Re: Newbie Eclipse AJDT Install Question [message #24135 is a reply to message #24115] Sun, 29 June 2003 17:38 Go to previous message
Brian,
One more thing. According to the Resource Perspective are you actually
seeing .class files being created under your project home when you try and
do a build ? I would imagine not (hence the absence of any main classes
when you try and run the application) but just thought I should ask.
Bye for now,
George
wrote:
> Hi George,
> B.
>> Hi Brian,
>> be certain.
>> Good luck !
>> > Hi,
>> the
>> the
>> > B.C.
>> -- George
George
AJDT Development
Re: Newbie Eclipse AJDT Install Question [message #569275 is a reply to message #24105] Fri, 27 June 2003 11:03 Go to previous message
Hi Brian,
Good luck !
> B.C.
George
Re: Newbie Eclipse AJDT Install Question [message #569302 is a reply to message #24110] Fri, 27 June 2003 12:44 Go to previous message
Hi George,
B.
> Hi Brian,
> Good luck !
> > Hi,
> > B.C.
> George
Re: Newbie Eclipse AJDT Install Question [message #569329 is a reply to message #24115] Sun, 29 June 2003 17:29 Go to previous message
(b) level of Java
preferences
Bye for now,
George
wrote:
> Hi George,
> B.
>> Hi Brian,
>> be certain.
>> Good luck !
>> > Hi,
>> the
>> the
>> > B.C.
>> -- George
George
AJDT Development
Re: Newbie Eclipse AJDT Install Question [message #569354 is a reply to message #24115] Sun, 29 June 2003 17:38 Go to previous message
Brian,
Bye for now,
George
wrote:
> Hi George,
> B.
>> Hi Brian,
>> be certain.
>> Good luck !
>> > Hi,
>> the
>> the
>> > B.C.
>> -- George
George
AJDT Development
Previous Topic:Newbie Eclipse AJDT Install Question
Next Topic:Newgroup problems: An update
Current Time: Mon Sep 01 00:30:50 EDT 2025
Powered by FUDForum. Page generated in 0.11281 seconds
