Home » Newcomers » Newcomers » Eclipse HTML editor rules?
Eclipse HTML editor rules? [message #245177] Wed, 09 January 2008 19:41 Go to next message
Originally posted by: bill.davidson.gmail.com
I'm not actually an Eclipse new comer but I'm not sure where to go with
this question. I recently started a new job working on an old legacy
servlet application. Apparently they either didn't know JSP or it's
old enough that it wasn't available at the time. In any case, they
designed their own HTML template system to solve essentially the same
problem. In order to replace values in the HTML template with values
from the database they came up with a special syntax that embedded these
values in HTML comments. Something like:
<!-- Some.Name.Value -->
They've always used regular text editors like vi and such. I'm trying
to use Eclipse and am having trouble with the HTML text editor.
Eclipse's text editor works just fine when the comment is contained by
a begin/end tag pair. In other words:
<select><!-- Some.List.of.Options --></select>
works perfectly. However, the Eclipse editor gets confused when one of
these HTML comments is inside a tag attribute. For example:
<img src="<!-- Some.Image.URLName -->" alt="">
is flagged as an error by the HTML editor as soon as it sees the "<!--".
It screws up the text coloring and flags other errors due to losing its
place in parsing the tree.
BTW, Vim's HTML text coloring parses this just fine. It treats the
comment as just regular text inside a set of quotes for an attribute.
Is there some way to modify the Eclipse editor's rules for this? I've
been looking all over but I can't seem to find the right Google
incantation for where those rules are or how they are implemented.
Looking through the Eclipse directory isn't going well either. Can
anyone point me to the appropriate files or better yet, docs on how to
fix this?
Obviously, this isn't earth shatteringly bad but it's just plain
annoying.
Re: Eclipse HTML editor rules? [message #245195 is a reply to message #245177] Thu, 10 January 2008 07:18 Go to previous messageGo to next message
Bill,
Comments below.
This doesn't look to be valid XML though....
I'm pretty sure this isn't valid XML. I think you need to use "&lt;!--..."
> fix this?
I think it's best to ensure that the XML is valid and then likely the
editor will colorize it the way you want.
> annoying.
Re: Eclipse HTML editor rules? [message #245215 is a reply to message #245195] Thu, 10 January 2008 13:13 Go to previous messageGo to next message
This is HTML, not XML or XHTML. It doesn't matter. I can't change
their templating system anyway. This is a big legacy system.
Also, &lt; is sure to break the templating system.
Again, HTML != XML and does not have to conform to XML's rules.
Indeed, even HTML 4.01 strict does not conform to XML's rules.
Also, by the time the markup gets to the browser, these are
replaced with data/markup from classes that get the data from
the database. The example above would become something like
this for the browser:
<img src="http://www.MyCompany.Com/images/logo.gif" alt="">
The only things that read the file in template form are the
templating system and any text editors used to edit the templates
(like Eclipse or Vim for example). Hmmm. Is there a plugin to
use Vim inside of Eclipse?
If I can't find out how to modify the parsing rules for Eclipse,
then my only other option is to live with the annoyance of Eclipse
thinking the template markup is broken, when it is not.
Re: Eclipse HTML editor rules? [message #245217 is a reply to message #245215] Thu, 10 January 2008 13:24 Go to previous messageGo to next message
Bill,
Comments below.
I see.
>> "&lt;!--..."
If it's looking at raw characters then without a doubt.
There's vi plugin which I use and love http://satokar.com/viplugin/ but
I don't think that solves your colorization problem. I'm not sure where
it's done but given that it's valid HTML it seems reasonable to open a
bugzilla about it. In that bugzilla you could offer to help fix it if
someone would be so kind as to point you to the source code so you could
try to fix it. Do you know which editor you are using? At least for me
with just the platform installed the plain old text editor doesn't seem
to do colorization...
Re: Eclipse HTML editor rules? [message #245222 is a reply to message #245215] Thu, 10 January 2008 13:49 Go to previous messageGo to next message
You might like the Eclipse Colorer editor. http://colorer.sourceforge.net/
It seems to handle your template markup well.
There's an Eclipse update site for it at
http://colorer.sf.net/eclipsecolorer/
Steve
>> "&lt;!--..."
Re: Eclipse HTML editor rules? [message #245233 is a reply to message #245217] Thu, 10 January 2008 15:18 Go to previous message
I'll have to look at that. Sometimes, ":s" can do things that search
and replace cannot.
> bugzilla about it.
I'm not exactly sure it's HTML compliant. The HTML 4.01 docs seem to be
a bit fuzzy on the subject from what I can tell. It doesn't matter
though since I can't change the templating system.
I'm using the built-in HTML editor. I've got Eclipse 3.3.1.1. I took
the one labeled "Eclipse IDE for Java EE Developers" from the main
download page. Maybe it includes an HTML editor plugin you don't have?
From Window->Preferences->Web and XML->HTML Files", there are some
options to modify the editor. Unfortunately, nothing is vaguely related
to what I want that I can see.
Previous Topic:Hidden Text on Eclipse Editor
Next Topic:Java crashing on Ecliipse startup
Current Time: Thu Jul 17 11:09:23 EDT 2025
Powered by FUDForum. Page generated in 0.12840 seconds
